Piper Pacer
Member
Unfortunatly I think your right. There were several other things that were done that makes me feel the same way.
I found a lot of white crap in the bottom of the transmission case and I will need to flush it out some way with something. What would you use to flush out the system?
On another note I'm taking the fuel injection pump in today to have a health check performed on the pump since it was hard to start without injecting starting fluid. I'm assuming that it was caused by the scored cylinder and low compression but not sure and it's not that easy to just pull the pump without pulling the front cover off the tractor. They want $125 to just run the health check on the pump and if it needs repair then it's $360. Pretty high....
