Poly vs steel spreader...
   / Poly vs steel spreader... #21
Manure spreaders are different ... no way to conveniently maintain against corrosion, and plastic can be backed for stiffness where needed and no potential for hi speed rubbing. Plastic broadcast spreaders can be destroyed by the agitator too quickly to perceive and react.
larry
My bad on the manure issue. I meant just manure on anything metal not just a manure spreader. Those things stayed covered in manure year round if used on a daily basis. I can't count how many of them we went thru. As with most product threads on this site, which is great I might add, half like it half prefer something else. If my poly fails me I'll know to switch to a metal one.
Not to change the subject but I see where you own a KK tiller. What size and model is it and how do you like it? I'm looking at the KKII TG-60 model. They seem to match up with the Woods GHT-60 but for about half the cost. I can't find anything wrong with them on paper, looks like a good unit. So far I haven't heard anything but good things about them.
Thanks
   / Poly vs steel spreader... #22
Thanks
I have a KK-II 60" Gear drive. I cannot find the manual on it right now. Had it since 2005. A little oil seepage started promptly from the tine drive gearbox seal, but no mechanical problems and havnt added oil. The level really isnt critical as long as the bottom gear can reach and bring it up to the higher gears. it came with PTO slip clutch for $1095 as I remember. Iv run it weighted down and 45PTOHP input-no indication of problem. My normal use is with 25-30HP
larry
Informational Lot - Financing (A55314)
Informational Lot...
2014 JCB 930 (A53314)
Pull-Behind 66in Smooth Drum Ballast Roller (A51691)
Pull-Behind 66in...
LINCOLN ELECTRIC RANGER 225 GAS WELDER/GENERATOR (A54757)
LINCOLN ELECTRIC...
2007 International 4300 (A53314)
2007 International...
2010 Komatsu WA320-6 Articulated Wheel Loader (A55787)
2010 Komatsu...
