Installing Glow plug conversion Kit
/ Installing Glow plug conversion Kit #1
Becharpa
Bridgton, maine
Mahindra 2015HST
I have a Mahindra 2015hst and purhased a glow plug conversion kit that extends the Glow plugs from 3 seconds to 10 seconds. However, I'm such a novice i have no idea how to install them? Any help without having to bring it to a mechanic?
/ Installing Glow plug conversion Kit #2
I'm not a mechanic, but it sounds like you want to get more heat to your block before crancking it over.
Can't you just cycle the glow plugs a second time (i.e. cycle once, turn back to the off position, and then cycle again before crancking)?
Let me also say that I just started my 3-year old 3215 the other day at -12 degrees by doing this - without problem.
Also, if it's any colder than that, I'm not sure how you're going to stand being on the tractor.
/ Installing Glow plug conversion Kit #3
I dont see how he could stand it at -12
/ Installing Glow plug conversion Kit #4
Couldn't stand it - was on the tractor for all of about 15 minutes. Had to go back in the house and thaw the ice cubues (i.e. toes).
/ Installing Glow plug conversion Kit #5
This is an old thread, but I'm hoping Tractorbynet will notify you that you have a message. I have a 2006 Mahindra 2015 (gear) and also need to put in a conversion kit. I would appreciate hearing what was involved and if it helped. Feel free to email me at kolkmeyer@operamail.com or if you prefer, you can call at 417-877-0135. Thankyou very much. John
/ Installing Glow plug conversion Kit #6
I have a 2015 also, acted like the glow plugs weren't working. I asked the dealer and he said it wasn't the glow plugs but was the whatchamathingy that caused them to glow, this after I had new plugs installed. it starts very well without using the igniter untill cold weather sets in. I have to get the thingy replaced as it is getting colder and it starts like it has no glow. Somebody on here must be able to explain better than I.
/ Installing Glow plug conversion Kit #7
The update includes different glow plugs, and a different glow timer. Awiring harness adapter is also needed. I think I still have the pieces, to do this update, in stock.
/ Installing Glow plug conversion Kit #8
What a great website. I made reference to a 9 month old thread, and immediately got feedback. Twice before I have also been able to fix problems that were beyond my skill level, thanks to other members.
With regard to the Mahindra 2015 and 2615 glow plug conversion, I was able to pull up Mahindra Parts Information Bulletin # 15-E/08/2005 which gives information and pictures of the kits which convert these tractors from a 3second to 10 second glow cycle. You basically get a new timer, glow plugs, and what looks like a short(approx. 5") wiring harness with 1 or 2 plugs on each end. I assume the old existing plugs connected to the tractor wiring do not match the plug recepticles or pins on the new timers, and this adapter/harnesss allows you to make the connection. This is what I am not sure of, and was hoping someone could clarify.
The suggestion of repeatedly turning on the key to repeat the 3 second glow cycle to get more heat, doesn't seem to work with my tractor. After the first 3 second glow, it won't immediately give you another 3 seconds if you turn the key off and on. I think I need a timer and plugs anyway. The timer seems to be really inconsistent, and when I removed the plugs and hooked jumper cables directly to them, two do nothing and the third only gets warm after 30 seconds. Maybe the timer burned them up? Any input would be appreciated. Thanks again.
/ Installing Glow plug conversion Kit #9
Not wanting to hijack this thread...But, I recently started having issues with my 2615. It hasn't failed to start, but the GP indicator light comes on randomly and/or stays on when it shouldn't. After being guided to the relay being under the steering wheel behind the plastic cover, I've pulled off what I think is the problem, cause when I fiddle with it it causes the indicator light to go on/off. It's labeled "NGK QGS Controller", model # S85NE. Is this the relay & timer in one? Are they still available anywhere? Google returns little or nothing about this model #, so I'm guessing this is one of the reasons for the conversion kits. If they aren't available, I guess a conversion kit is in my future...how much are they?
Thanks
/ Installing Glow plug conversion Kit #10
Get the conversion kit. It comes with new cable connections. I put one in today.
/ Installing Glow plug conversion Kit #11
Anyone know how to do the wiring or where I can get this information? thanks
/ Installing Glow plug conversion Kit #12
They must be electrically disconnected, then unscrewed from the head using a good fitting six-point deep socket wrench. Put some diesel on them before and let them soak for 36 hours first. Use a torque wrench to reseat the new plugs, but be sure the threads are correct before you put them in and use the new gasaket that comes with themj, not the old ones. I do not know the torque settings, sorry. I would take the tractor to a mechanic if I were you. It is a small job, but if you screw up it will cost you a new head plus gasket. 50 bucks for a mechanic is better than eight hundred for a new head, IMO
Good luck!
Jix
/ Installing Glow plug conversion Kit #13
The wiring is easy, pull the black plastic cover below the steering wheel, ( maybe 3, 10mm headed bolts) The timer should be mount behind cover, disconnect plug from old one, unbolt and install the new one, connect the harness that comes in the kit to the timer and the other end to the original plug in the harness.
/ Installing Glow plug conversion Kit #15
I bought the conversion kit today. A dealer/mechanic I know gave me an "in service" on how to install and I feel good about doing it. We will see......
/ Installing Glow plug conversion Kit #16
This will be one of the easiest of installations. I did mine in less than 1/2 hour. You might also put some anti-sieze on the threads of the plugs. I didn't on mine, but just now thought of it. Hopefully the 10 sec. timer and new plugs will never need replacing.
/ Installing Glow plug conversion Kit #17
Thanks AchingBack. You have always been an inspiration here!
/ Installing Glow plug conversion Kit #18
Just did the conversion on mine. The biggest pain was getting the right one. I needed the two plug one but got the single plug. So I had to reorder and it was more money for the two plug one.
Then when I got it I realized that there were a bunch of extra pieces with the kit that I didn't need. The mounting bracket and a plug harness.
I was having a lot of trouble with my tractor starting lately in the sub zero temperatures. We will see how much this helps.
/ Installing Glow plug conversion Kit #19
There is a break as to which kit is needed according to the serial number on the 2615. I hope mine comes in this week. I have 1095 hours on it and it is hard to start period of late. A lot worse to start in the cold weather. Let us know how this project goes for you and I will do the same.
/ Installing Glow plug conversion Kit #20
Completed putting on the conversion kit today. It was not difficult and did not take much time. Best of all - - it cranks GREAT now. Thanks for the help folks!!
KUBOTA L3901D TRACTOR (A59823)
KUBOTA L3901D...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59905)
2019 FREIGHTLINER...
2016 KOMATSU D65PX-18 CRAWLER DOZER (A60429)
2016 KOMATSU...
UNUSED IRANCH 38" MINI LAND LEVELER (A60432)
UNUSED IRANCH 38"...
2014 FREIGHTLINER 108SD CONCRETE MIXER TRUCK (A59823)
2014 FREIGHTLINER...
2018 John Deere 30G Mini Excavator (A59228)
2018 John Deere...
