What do you do to keep your pressure tank/well head from freezing?
   / What do you do to keep your pressure tank/well head from freezing? #61
SPYDERLK said:
Item #3580K22 Near page bottom. Self regulating.
McMaster-Carr
larry
Yeah. I have something similiar.
But I need to run a 12/2 line down to do it right.. Tired of the extension cords...
   / What do you do to keep your pressure tank/well head from freezing? #62
Dan,
Do you want heat or light?
What I'd do- buy two regular pigtailed light sockets from HD or Lowes. Buy two 200 watt bulbs. Wire the sockets in series. The bulbs will last virtually forever running on 1/2 voltage but will produce 100 watts total of heat.
If that isn't the correct amount of heat substitute bigger/smaller bulbs.
The important thing is to use 2 in series so they last many years.
Try to set them up so you can see the glow from the house, maybe a clear lucite/acrylic rod through the pump house as an "eye". Glance out there occassionally in the winter to confirm they are working and turn them off in warm weather.
Attached is a pic of the sockets and one of a bulb.
   / What do you do to keep your pressure tank/well head from freezing? #63
:confused: Cant you get to pump power? Just tap 110 off that. Those shorter self reg tapes draw near nothing [fractional A] in cold operation and virtually taper to full off in Summer.
larry
   / What do you do to keep your pressure tank/well head from freezing? #64
larry
I've never heard of those..can you provide a link or something?
   / What do you do to keep your pressure tank/well head from freezing? #65
   / What do you do to keep your pressure tank/well head from freezing? #66
   / What do you do to keep your pressure tank/well head from freezing? #67
   / What do you do to keep your pressure tank/well head from freezing? #68
SPYDERLK said:
:confused2: HUH? ... I did provide a link in Post#51 -- to which you replied.
I'm sorry.. I was using the droid..
   / What do you do to keep your pressure tank/well head from freezing? #69
I got it now..
So if I tap the power.. And only need to cover 5 feet of 1 inch, that chart says we should use 1.3 feet of cable...
But could I tap a 60 watt bulb and a temp controlled switch in there?
JOHN DEERE 5125R LOT NUMBER 24 (A53084)
JOHN DEERE 5125R...
HYSTER H55VM STRAIGHT MAST FORKLIFT (A51406)
HYSTER H55VM...
2021 CATERPILLAR CB2.7 DBL DRUM TANDEM ROLLER (A52705)
2021 CATERPILLAR...
201707 (A54756)
201707 (A54756)
2014 BMW 328i Sedan (A53424)
2014 BMW 328i...
