Rear view mirror(s) for no cab JD 3000 series
   / Rear view mirror(s) for no cab JD 3000 series #11
hi roy. part # & prices for my mirrors al58554 mirror $55.00 m118822 support 15.75 lva14610 bracket 23.99 19m7800 screw [need 2] 1.30 14m7396 lock nut [need 2] 1.95 14m7296 flange nut .95 they sure arn't cheap but what jd part is? hope this helps........................bud
   / Rear view mirror(s) for no cab JD 3000 series #12
Way I see it is just under $100 per side. Nope...not cheap.
   / Rear view mirror(s) for no cab JD 3000 series #13
It's real easy on the 300CX FEL. There is a hole at the top of the mast. A piece of 3/8" ID clear plastic tubing fits perfectly. Bought two 5" round convex mirrors (like seen on OTR trucks for about $7 each. The mount stud fits perfectly inside the plastic tubing. Four flat SS washers.
$14 = rear view mirrors on each side.
   / Rear view mirror(s) for no cab JD 3000 series #14
Cinder
A pic or two of that mirror mounting would be great.
   / Rear view mirror(s) for no cab JD 3000 series #15
Cinder
Hi Beenthere,
Look at my picture.. I changed the mirrors on my motorcycle, and took one and mounted it on the FEL... There's a hole already there! :)
I also have a mirror mounted at the top of my homemade canopy!.. You can see it also in the picture... They come in handy when traveling on the highway, and makes it easy on the neck! :D
   / Rear view mirror(s) for no cab JD 3000 series #16
JD4300
Thanks, I like that.
Only I need to think on how working in the woods would like it. :eek:
And most of my "rear view" concern and need is on the road when plowing snow (when the FEL is off). But going to think on that some.
   / Rear view mirror(s) for no cab JD 3000 series #17
JD4300
I work a lot in the woods cutting firewood, and the mirror really doesn't stick out that far!
JC Whitney has some ''cheap'' motorcycle mirrors.
Since you take your FEL off, Then you might have to get the mirrors that would clamp around your ''grab handles''.... Like the kind for an ATV.
60in Forklift Forks (A52378)
60in Forklift...
2019 Allmand Night-Lite V-Series 7 kW S/A Towable Light Tower (A52377)
2019 Allmand...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A53422)
2013 Ford F-150...
2016 Case 821F Articulated Wheel Loader (A51691)
2016 Case 821F...
2016 Dodge Ram 3500 Stahl Enclosed Service Truck (A52377)
2016 Dodge Ram...
UNUSED SDLANCH SDLL50 STAND ON SKID STEER (A54756)
UNUSED SDLANCH...
