If you could post some links I'd appreciate it. I looked and couldnt find much. Thanks for all of your help. One other thing I thought of. My 3 point would drop overnight if I left the arms up when I shut her down. That seems like a blown seal or something...to me.
Wood butcher,
Below I'll attach couple of threads that probably give you more information that you might need but they are good as many good folks had great input there as well. I'm going to give you a short synopsis here, read them and if you have questions then bring it up. Guys here and myself will be glad to help. I noticed you did have issue with your lift system and it covers it well.
Although, there might be several reasons causing slow drop of 3 point arm probably 9 out of 10 is lift piston piston seal. On many tractor it is quite involved just to get to the piston but in Ford/Shibaura it is quite easy and top cover need not be removed. Cost of new seal is under $10 and it take about an hr tops to do it. it take less than cost of the oil change to have a brand new seal installed. This is covered in my link.
Few pointers to share with pump overhaul.
1. The banjo connection on the pump has O-rings, I replaced them all although it was not necessary. A package of assorted metric HF o-ring will be all you need.
2. Cleanness is very important as far as inside the guts of the pump, would not care about outside.
3. pump comes in several different sections (3 with ours), make sure to put some scratch mark (witness mark) to remove any guess work later on when you put things back.
4. Remove connecting bolts (with allen head) in a criss cross fashion and put them back the same. don't over tighten as you might damage the rubber seal and orings. I have not seen torque rating but make them just" good and tight).
5. inspect the inside of the case and gears for sign of damage , change of color due to overheating. A partially damaged pump might still pump some but efficiency and the flow is severely reduced.
6. You'll have bushing and friction bearing inside the bushing (same as crankshaft bearing). The tolerances are tight so don't force thing when the fit is tight. like the engine, the wear pattern might be unique in each cylinder and piston. same thing is true when pumps break in. The bushing is interchangeable, make sure to put witness mark to put them back in exactly the same spot. orientation of the bushing is very important because by built in geometry they form inlet and out let chambers. Take picture so if memory fail you you can go back to refresh.
7. After cleaning all the inside make sure to use a generous amount of fresh NH-134 oil to get a film coat on all parts.
8. Pump overhaul kit does not come with shaft seal and need to be purchased separately.
Take a look and let us know if you have any questions.
JC,
http://www.tractorbynet.com/forums/new-holland-owning-operating/88973-sos-i-have-my-first.html
http://www.tractorbynet.com/forums/new-holland-owning-operating/90819-my-f-1700-testing-my.html
