power beyond to run snowblower?
   / power beyond to run snowblower? #1
rjm5133
Member
S.E. PA
5-John Deere 855's, 2155, 2555,5520, 2-5075e's 4520, 1070, 2720, 4-kubota ZD331, M7040
i am looking to mount a hydraulic powered skid steer to the loader arms of my jd 4520. first quetion is will a power beyond kit run the motor? how many gpm will it flow? and third is does anyone have any recommendations on what blower to run. looking for something in the 6 to 8 ft range.
   / power beyond to run snowblower? #2
The flow will depend on the valve you choose. It should be a little higher than the hyd output in GPM. Are you saying that you want to install a hyd motor driven attachment . The PB outlet is designed to flow the total flow for the valve spec. If you will be using stacked valves, make one of them motor spool setup, perhaps with detent.. You can use a 4 way valve, but you have to be careful about releasing the levers back to neutral, because the hyd attachment might still be turning and will begin to act as a pump, and the fluid needs a place to go. A double relief valve across the motor will suffice to re-route the fluid from output to input of the motor.
   / power beyond to run snowblower? #3
You will not have near enough flow to operate it, sorry-especially a 6-8' one!
yea i kind of half expected that. i have seen them mounted this way but im guessing those machines had a pump run by the pto
   / power beyond to run snowblower? #5
kennyd,
thanks for your input, ill check out those links. i have a rear mounted pto blower now, just starting to research the front mounted options so any info helps
   / power beyond to run snowblower? #7
   / power beyond to run snowblower? #8
I have been told that Buehler (farm king) will be offering a loader - skid mount - snowblower and powerpack this fall in the 84" size.....well have to see how much they want for it. Im not sure why the hydraulic res systems are soo much $$$$
   / power beyond to run snowblower? #10
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2012 Ford Explorer SUV (A53117)
2012 Ford Explorer...
2012 John Deere 7230R (A53473)
2012 John Deere...
2018 FORD F-450 XL FLATBED TRUCK (A51406)
2018 FORD F-450 XL...
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
THE HANDLER II MIXER UNIT (A53843)
THE HANDLER II...
