Freds
Couild you explain the side-to-side float.?? What is that.??....I leave about a 2" "float" in the turnbuckles with my blower....Is this not what you are talking about.??
What I called side to side float Rick better called lateral float.
What the OP wanted to know was what would happen if one end of a snowblower dropped into his concrete gutter. The way my 3PH works and my snowblower is built, it would stay put and that side would not drop into the gutter. The end that remains in contact with the ground would support it, not to mention the whole cutting edge. In other words, the blower would not follow the contour on a lateral plane. Maybe pivot is a better word yet.
That's why I brought up my rear blade. I can take a pin out on my rear blade and if one side is far enough over a ditch or trench, it will drop into it. It will pivot and follow the contour, or "float". And that comes in mighty handy when using one on a crowned driveway.
