Belleville washers-which way to apply?
   / Belleville washers-which way to apply? #1
nickel plate
CA
2002 New Holland TC40S
I'm just finishing up a rear remote installation and it is now time to nut down the stack. On the outboard face of the end cap, which direction does the conical/spring belleville washer go? Cone top towards the outboard face of the end cap or cone top towards the nut? I have four threaded rods installed, four of these washers and four nuts to lock down the stack.
Please don't guess-Wikipedia shows a drawing one way and another fastener site describes the other way. I called two local branches of a company named Fastenet and they don't know-how do you succeed in sales if you lack product knowledge? Thanks.
   / Belleville washers-which way to apply? #2
I'm just finishing up a rear remote installation and it is now time to nut down the stack. On the outboard face of the end cap, which direction does the conical/spring belleville washer go? .
Not sure on your particular application, but I always put the cone toward the nut on every other thing that I have worked on.
Thats an easy one. Lots of BS and a good smile:D
   / Belleville washers-which way to apply? #3
All of them I have ever worked on came with the cone towards the nut. They apply a locking force to the nut. They should not be so tight as to flatten out. We have many of them on our electrical gear.
   / Belleville washers-which way to apply? #4
Yes, that is exactly how they work, and finished product on the bottom white insert.
   / Belleville washers-which way to apply? #5
As per jonyuma ( They apply a locking force to the nut. They should not be so tight as to flatten out. We have many of them on our electrical gear. )
That is how in the electrical trade I would tighten them down. In the mechanical trade I know they can be stacked to achieve a predetermined thrust load but that is not the subject at hand.
Craig Clayton
   / Belleville washers-which way to apply? #6
Craig Clayton
Craig, you might have me there. Nut down the stack? ? Why not common split lock washer, or better yet a star lockwasher on the nut. Myself I like the Nylock locking nuts..for static loads..Jy.
   / Belleville washers-which way to apply? #7
I think the stack comment has been misunderstood. We have large mechanical machines that have stacked belleville washers in them to thrust against. They are stacked to give a known value . In this way if the thrust exceedes a known movement a microswitch is touched and the thrust action stops. I can not recall if they are back to back or nested.
The only reason the bolts would have belleville washers on hydraulics stacks is for thermal expansion of the block.
Craig Clayton
   / Belleville washers-which way to apply? #8
I have used Belleville washers when thermal expansion of the flange is greater than thermal expansion of the bolt - assume aluminum flanges and a steel bolt. This results in the bolt tightening when the assembly heats up. If it tightens too much there's a risk that the aluminum will yield and when the assembly cools back down, the bolt will be loose and may rotate out due to vibration. The Belleville washer's spring effect (if not flattened when installed as some have noted) allows the thermal growth to occur without causing yielding of the flange material.
-Jim
   / Belleville washers-which way to apply? #9
I agree with the majority here. Cone side to the nut. Pay attention to recommended torque specifications to avoid flattening out. We used to use stacks of washes, back to back not nested, to act as a sort of spring tensioner.
   / Belleville washers-which way to apply? #10
We used them as Baby Grand states....in high temperature applications. On rotary tube furnaces, the tube flange bolts can break if the washers are not used. There is a tremendous amount of force applied to the fastener from the effects of thermal expansion....to the point where thread damage occurs (stretching) or complete failure (breaking). Although somewhat expensive, the use of them greatly reduced the time involved in removal of the bolts....stretched threads are a PITA to deal with. A torch was often used to remove the damaged bolts....which often resulted in damage to the flange faces.
And yes...the cone goes towards the fastener ends.
Mini-Excavator Heavy Duty Grapple Attachment (New/Unused) (A59225)
Mini-Excavator...
2015 Ford F-550 Crew Cab Godwin 184U Mason Dump Truck (A56858)
2015 Ford F-550...
2015 CATERPILLAR 930M LOADER (A58214)
2015 CATERPILLAR...
2023 FORD F-250 (A58214)
2023 FORD F-250...
LOT: (1) Shelf of Takeuchi & Donaldson Parts & Filters (CONTENTS ONLY) (A59076)
LOT: (1) Shelf of...
2025 Starvox SV-480 23HP Mini Skid Steer Loader (New/Unused) Includes Bucket and accepts multiple... (A59225)
2025 Starvox...
