Put her in pond - not bad but what now?
   / Put her in pond - not bad but what now? #1
jimmyj
Elite Member
Ontario Canada
Allis Chalmers 616 (Two) and a Kioti CK30 HST with loader and backhoe
A while back I put the back end of my tractor (CK30 hst) into the water. It was in up to the rear axle for about 2 days (took a while to get it out). I went to the dealer to ask if there were breathers or any other areas water could get into the differential or ?? and he said I was not deep enough to worry. He also said I could check my oil and see if it was cloudy. I did take an oil sample and it was beautiful, fresh and nice, looked perfect.
However the other thread about a tractor with problems makes me all worried.
http://www.tractorbynet.com/forums/parts-repairs/192962-ok-whats-wrong-pic.html
Are there any tips you have about what else I could check or do?
Here are pics of how deep I was. I really don't think I was in that deep but now I'm all worried.
   / Put her in pond - not bad but what now? #2
I was not aware that we had ponds in Canada that were not frozen aaaaall year round.
Why not drop the oil completly, and put in fresh. Then let the old oil sit in a quiet corner to see if any water ever forms on the top.
Craig Clayton
   / Put her in pond - not bad but what now? #3
Just my opinion, but looking at the pics it sure doesn't look like you were anywhere close to deep enough to cause that kind of trouble.
Mark
   / Put her in pond - not bad but what now? #4
I agree with your dealer.
It doesn't look like you were in deep enough to worry about.
If the oil is not milky/cloudy you will be fine.
   / Put her in pond - not bad but what now? #5
I thought I've checked for leaks in rear tires every way possible but you've got one up on me and I admit defeat.:laughing::laughing:
   / Put her in pond - not bad but what now? #6
Craig Clayton
Water will never be on top...it is heavier than oil;)
   / Put her in pond - not bad but what now? #7
The axle shaft was still above water, so water wouldn't enter at axle seal. the breather should be on top under the seat area. I would just check the dipstick for cloudy oil every ten hours of use, until you get tired of doing it. There will be something new that comes along to worry about, and this will become just another funny memory.
   / Put her in pond - not bad but what now? #8
Nothing to worry about... I really like the photos... many angles :D Two day, eh? How did you finally get her out?
Thanks everybody. I feel better now.
The stupid thing is this was the 2nd time in 8 weeks I did this. (Two different spots mind you). Had to get a skid steer in to pull me out as there was not enough room for a truck. Problem was that as the skid steer pulled, it's front 2 tires came up off the ground so it was a bit of a chore. We did it though. I had to leave the box blade in the mud and drag it out later though as it was dead weight stuck deep in mud.
And yes, the tires were air-tight!
   / Put her in pond - not bad but what now? #10
Where was Jethro when all this was going on?
I remember him lifting your truck by himself. Seems like either he or Elly May coulda drug it out for ya.:laughing::laughing::laughing:
2 Vintage Metal Signs (A48081)
2 Vintage Metal...
2023 CATERPILLAR 259D3 SKID STEER (A51242)
2023 CATERPILLAR...
2008 John Deere 2305 Tractor (A50514)
2008 John Deere...
2014 International Durastar 4300 Terex BT3063 30,000lb 63ft Crane Truck (A50323)
2014 International...
30ft Pole S/A Towable Trailer (A49346)
30ft Pole S/A...
2016 John Deere TS Gator Utility Cart (A48082)
2016 John Deere TS...
