Moving the fuel pump on a 422/425
   / Moving the fuel pump on a 422/425 #1
MuncyBob
N Central PA
PT 422
It makes sense to move the fuel pump to an area of less heat. For those that have done this, where did you relocate it to? Does the location need to be an apprx same height as original location in relation to the carb or fuel tank outlet?
   / Moving the fuel pump on a 422/425 #3
I removed the stock pump and installed an electric as far away from the exhaust heat as possible.
My vaporlock problem still existed but not as much. It only was completely cured when I installed the large fan on the engine cage.
http://www.tractorbynet.com/forums/power-trac/99371-pt422-aux-cooling.html
Phil
My vaporlock problem seems to be cured by a combination of electric pump, insulated fuel lines, and using only premium fuel. I went all last summer and this winter with no problems.
2003 Pierce Tilt Cab Foam Pumper Fire Truck (A51692)
2003 Pierce Tilt...
43029 (A51691)
43029 (A51691)
49" X 74" EXPANDED METAL RAMP GATE (A51247)
49" X 74" EXPANDED...
UNUSED JCT 84" HYD DOZER BLADE (A51248)
UNUSED JCT 84" HYD...
2013 International WorkStar 7400 4x4 Altec DMA71 Insulated Digger Derrick Truck (A51692)
2013 International...
MURRAY 20" SIDE DISCHARGE GAS PUSH MOWER (A51248)
MURRAY 20" SIDE...
