3316 and a plow and disc
   / 3316 and a plow and disc #1
jwcinpk
Welfare Capital of the World...KY
2009 Mahindra 3316 HST-2008 Mahindra 7010 cab - 2004 Mahindra 6000 4X4
Looking for a plow and disc to pull with the 3316. I'm assuming it's a bit much to ask the 3316 to pull even a 14 2 bottom? What size disc are you guys using 5ft?
   / 3316 and a plow and disc #2
I pulled a 14in 3 bottom with a 3325 while had tire problem with my bigger tractor went slow but did a good job for what it is pulled in heavy north ga soil
   / 3316 and a plow and disc #3
I think that it will pull that 14-2 bottom with ease. I'm looking for a good 6' wide disk for mine. Joel are your tires loaded? If not, load them, you won't believe how much better your little tractor will be. I tried to get by with out loading the tires on my 3215 because I move it around some. But it just wasn't getting the job done, filled all 4 tires, oh what a difference, day and night with what the tractor's capabilities are with the tires loaded. :thumbsup: :thumbsup:
I pull this ditcher 18" deep and don't even know it's back there.
   / 3316 and a plow and disc #4
We have several 2-12 and 2-14 plows as well as some new and used 5-6 ft lift discs. Ken Sweet
   / 3316 and a plow and disc #5
mntviewranch where did that ditcher come from not to change subject but is that home made or store bought i like it alot from what i can tell from one picture
   / 3316 and a plow and disc #6
It is an old JD ditcher that I bought at an antique tractor show.
I picked up a 2-12 from Ken......I'll let you guys know how it does with it.
2018 FREIGHTLINER COLUMBIA GLIDER TANDEM AXLE SLEEPER (A52577)
2018 FREIGHTLINER...
2013 INTERNATIONAL SA615 ROUSTABOUT (INOPERABLE) (A52472)
2013 INTERNATIONAL...
County Line 3pt Auger (A50121)
County Line 3pt...
2016 Ford Explorer AWD SUV (A50324)
2016 Ford Explorer...
1987 Retrall Boat Trailer (A50121)
1987 Retrall Boat...
(30) 9 Box Macro Bins (A50121)
(30) 9 Box Macro...
