Markcuda
Exactlythe fuel mileage will probably still suck compared to Ford and GM's offerings.
I still think it's too early to say UREA injection is a good substitute. With all the problems with freezing fluid, clogged injectors and rising cost of DEF I would rather have the NOx Absorber Catalyst (NAC) system. No EGR problems yet on our diesel fleet trucks and all have over 100k and idle most of the day. Although, we don't have any DEF trucks to compare to either. The SMALL fuel mileage increase with the DEF hardly makes up for the cost of the DEF or the time spent re-filling the tank or the time lost de-frosting the tank.I'm pretty disappointed they didn't add urea injection to the engine, the fuel mileage will probably still suck compared to Ford and GM's offerings.
unlike the Ford torqueshift which is already showing mass problems/QUOTE]
What!, a Ford with Transmission problems??, can't be.![]()
Another great thing about the updated truck, you can still get a 6-speed manual transmission and mega cab. :thumbsup:
I have a hard time believing a 20-25% increase in fuel mileage. Just look at the last Heavy Duty Shootout and you will see the RAM was within 10-15% of the GM/Ford fuel mileage and the GM used almost half a gallon of DEF fluid. With the more powerful update, the RAM will stay in a higher gear and run at lower rpms which will probably match or beat the others in fuel mileage. Only future test will show...The local fuel oil supplier, who has both GM and Ford Diesel trucks by the way, told me that he is getting between 20 to 25 percent increases in fuel economy on his 2011 vs. 2009 diesel trucks.
It's coming, one of the editors of Pickuptrucks.com (Mike Levine) said "I *definitely* smell a HD Shootout ASAP. And Rumble in the Rockies, Part 2" in the comments of the article I posted.I would like to see the Dodge in the test pickuptrucks.com did in the Rockies last year between Ford and Chev.
Not for the "I need one bigger than you" crowd.:laughing:Getting a little silly.
Markcuda said:Not for the "I need one bigger than you" crowd.:laughing:
