Who has high-hour machines?
   / Who has high-hour machines? #1
Jay4200
Hudson/Weare, NH
L4200GST w/ LA680 & BX2200D w/ LA211
My L4200GST has 2600 hours on it (and those are PTO hours, not those hippy clock hours the new machines have), and I've put on about 600 of those hours since '05 when I got my tractor. I replaced both tie rods when I bought the machine (torn boots), and have given the machine frequent oil and filter changes, and I just replaced the starter (first big mechanical failure). There is a little spooge that forms around the fuel filter (I think it is the petcock) and the transmission site glass seeps a bit. The left bezel seal started leaking pretty bad this summer - makes a pretty good puddle (fills a spray paint lid after a few weeks). I just checked the oil level in the axle housing and it hasn't dropped measurably since I filled it up last fall, so it looks worse than it is, I guess - I plan to replace that seal once the weather warms up.
The tractor still runs and operates perfectly, and just about everything works (except the safety switches) but I'm counting on the tractor in the winter now, and I'm starting to worry about general reliability, simply because of the age/hours. Some solidarity would be nice.
So, who has high-hour Kubotas? What issues/repairs have been done in their lifetime? How many hours does YOUR tractor have?
JayC
   / Who has high-hour machines? #2
I believe I am at about 4700 hrs on my 1985 (?) L2550DT. Not sure though, not home to look.
Just the regular front axle seal problems otherwise it has been great. Had to do some little stuff but nothing I would consider chronic or because of poor quality. Replaced the loader bucket because the front edge was gone.
If stuff has broken it is usually because I expected it to do the work of a tractor twice it's size
   / Who has high-hour machines? #3
Does 27 hours count as high :laughing:. At the rate I've been putting hours on the tractor will be 50 years old by the time I hit 2600.
   / Who has high-hour machines? #4
I have 5600 hrs on a Case 1845C skid steer. If it will do another 5000 that will take care of me.
   / Who has high-hour machines? #5
We have them out with more then double that!
   / Who has high-hour machines? #6
Had a 1983 B 6100 with 11,000 (Thats right eleven thousand hours) used daily since new for moving and launching boats at our marina and blowing snow in the winter. Replaced it in 2006 with a B7510 which now is approaching 2100 hrs. On 6100 broke one clutch disc, brakes were grabbing very agressively after being replaced, engine was making oil the last year and we decided it was time to replace when the 3 pt started to drop all the time. If I get near the same hours from the 7510 and recently purchased L 3400 I'll be very happy
firemech
   / Who has high-hour machines? #7
:licking:Depends on how savy you are - If you can "McGuver" fix something then you are good to go. If you can't then you need a new machine and then a backup new machine!!!:thumbsup: I used to sweat the small stuff but now I only sweat the medium stuff!!:licking: but then my name is "funwithahoe"!!
   / Who has high-hour machines? #8
I've got 1300 hrs on my Kubota L5030HSTC, have 4000+ on my MF. If maintained I'd say they are as reliable as new unmaintained machine. If you let every thing go until it breaks don't expect reliable use at high hours.
   / Who has high-hour machines? #9
No idea how many hours are on the maintainer, but I suspect a few.:laughing:
Well, I'd say that's about right...close to 50 anyway :)
JayC
2015 FORD F-150 (A50854)
2015 FORD F-150...
2001 INTERNATIONAL 2574 6X4 (A51406)
2001 INTERNATIONAL...
2014 ORTEQ ENERGY SERVICES MANIFOLD TRAILER (A50854)
2014 ORTEQ ENERGY...
SCREENER (A50854)
SCREENER (A50854)
2021 Cat D5 LGP Dozer (RIDE AND DRIVE) (A50774)
2021 Cat D5 LGP...
Lay-Mor Sweepmaster 400 Broom Sweeper (A49461)
Lay-Mor...
