middle buster
   / middle buster #1
deereman10
Elroy, WI
John Deere 2440
So i'm trying to think of a way to plant 500 christmas trees and 7 acres of pumpkins this year with minimal tilling. I do not have a no till planter and i'm not buying one at this point. I'm toying with the idea of using the middle buster to make a row every 5 feet. Good Idea? Bad idea? Other Ideas?
   / middle buster #2
A planting bar would do a better/faster job I think.
   / middle buster #3
How big are the trees you want to plant???
A post hole digger might work a little faster for the trees. A middle buster might not get you a deep enough trench for the trees. But that depends on how big they are.
   / middle buster #4
How big are the root systems on the trees? They need space to spread quickly and easily. I get about 12 inches form my middle buster, and some falls back into hole immediately. Jy.
   / middle buster
Trees are 6-12 inches tall. Getting the middle buster 12 inches into the ground would definately be enough for the roots.
   / middle buster #6
That JD2440 has enough hp to bury a MB 12 inches and pull a trench. I used my little 2005 Kubota B7510HST (21 hp engine, 17 hp pto, 4WD, hydrostatic tranny) and a King Kutter MB from Tractor Supply to plow the areas around my new house for landscaping to about 8" depth in fairly soft soil.
Just be sure to get a stout MB--that little KK MB I used would probably get bent quickly trying to dig to 12 inches. You may have to get out your welder and reinforce your MB with some steel bar.
   / middle buster
What brand do you recommend if not KK
   / middle buster #8
You’re going to spend FOREVER getting 6”-12” trees planted using a middle buster, and they won’t be panted well. Get a planting bar and it’ll take about 10 seconds to plant a tree.
2014 Stoughton 28ft Van Trailer (A51692)
2014 Stoughton...
2015 Ford Taurus SE Sedan (A51694)
2015 Ford Taurus...
2013 PETERBILT 388 MID-ROOF SLEEPER (A52472)
2013 PETERBILT 388...
ECHO PB-2520 GAS HAND HELD BLOWER (A51248)
ECHO PB-2520 GAS...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
Target Ecoline Walk-Behind Concrete Saw (A49461)
Target Ecoline...
