Snow Equipment Owning/Operating Pictures of your snow weapons
   / Pictures of your snow weapons #821
It works but a blower/front blade would be better! :D
   / Pictures of your snow weapons #822
Here are a couple of pictures of mine Kubota b7500 with a rebuilt Kubota B222 blower and 302 loader. The toplink is electrically adjustable shorten it up and the blower runs on the shoes over the gravel, or lengthen it out to run through the ice on the asphalt drives. Chute rotation and damper are electrically controlled too.
   / Pictures of your snow weapons #823
I use a front and rear blade. I customized rear blade with hyd angle, sure is nice to plow snow with.
DDT
   / Pictures of your snow weapons #824
DDT
Have you got any close pics of the rear hydraulic angle? I'm curious if you did the same thing I did.
Sean
   / Pictures of your snow weapons #825
Rockgod
Here is what your L4240 HSTC would look like with a FEL mounted front plow.Works well,I am going to put the bucket back on and move some banks tomorrow...takes about five minutes with the QD.
   / Pictures of your snow weapons #826
Roy, your electric top link adjustment is interesting. Did you build it yourself?
   / Pictures of your snow weapons #828
Yes its a linear actuator I picked up surplus and then welded on forged top link ends from tsc. Doesn't quite have enough power to tilt the blower if it lifted on the arms, but once sitting on the snow does a good job tilting for asphalt or gravel drives.
   / Pictures of your snow weapons #829
My set up
   / Pictures of your snow weapons #830
Holder 240. Just got it today.:thumbsup:
Hydraulic spike driver (A56435)
Hydraulic spike...
SHOP MADE MANIFOLD TRAILER (A58214)
SHOP MADE MANIFOLD...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55853)
2006 iDrive...
KUBOTA KX057-5 EXCAVATOR (A52709)
KUBOTA KX057-5...
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A56435)
2023 Kubota...
UNUSED 89" LAND PLANE (A52706)
UNUSED 89" LAND...
