TODAYS SEAT TIME
   / TODAYS SEAT TIME #761
4.5 hours of plowing out the road to hunting camp. Forgot to take off the tooth bar, but the road is so bad it didn't matter. I am still not done, but I only have another 2-300 yards to go. 1 mile of winding rocky road, that hasn't been touched all year, 14-18 inches.
   / TODAYS SEAT TIME #762
Yesterday I was widening out a road with my one ton plow truck and got a little to aggressive and ended up with the truck under carriage hung up on the snow bank with one front wheel down in a little ditch. Luckily I was only 1/2 mile from home so I could walk back and get my tractor. I did a "little" shoveling behind the plow. ( Snow was up to my hips ! ) Hooked my logging winch to the pintle hitch on the back of the truck and pulled it out on the second try. The truck weighs 9000 lbs not including the dump body full of snow. Those winches can really pull.
   / TODAYS SEAT TIME #763
Seat Time is more snow time than anything else lately and a lot of it !
For the last two months, as with a lot of us, it has been snow, snow, snow, more the pile just to get more snow in and that will be the seat time for the rest of the week; we are suppose to get a couple of warm day (above 32).
My Little CC Yanmar 2450 is one great tractor for its size, moved all of the iced over snow and piled it well out of the way, dug through another 7 foot pile and clear up that area, man I love this little thing.
   / TODAYS SEAT TIME #764
I have a BIL in Woburn. He has been whining and complaining all winter. He sent some pictures and I can see why. There is no room for snow down there.
   / TODAYS SEAT TIME #765
Took the tractor over to the neighbor's to level out a bit of ground for them. About 30 minutes later it was nice and level, took out a small tree and a bunch of brush. It has been dry for several days so the ground was decent to work with. Forgot to take the camera. :mad: Then had a nice cup of tea and lemon loaf with him. Turns out it was his 76th birthday so got him a box of fire starter and matches. Great neighbors and always glad to help them. :)
   / TODAYS SEAT TIME #766
Moved more snow today. Probably wasn't necessary, but I wanted some seat time.:laughing::thumbsup::laughing:
   / TODAYS SEAT TIME #767
Recently it was a tad coolish here in Oklahoma with a record set up by the Kansas border of -31F. The lowest I saw on my weather station was -4 to -5 F at about 0700-0730 but the wind chill was about -15F. The Kubota Grand L 4610HSTC had a Harbor Freight battery minder hooked to it so the battery was charged if not warm. (Lower temps seriously reduce the cranking power of a battery.) It cranked just fine but did not fire. Tried again, same result...
Switched the key on again to recycle the glow plugs then off and immediately back on to give it a "double dose" of glow plug, advanced the throttle a little past the idle stop and hit it again. Immediately it began to fire a little so I continued to crank and advanced the throttle a little more and it cranked faster firing more and then took off running so I released the key. I held it at a fast idle for a few seconds and noted it was running quite smoothly so I reduced the throttle to the detent and it idled just fine, quite smooth.
This was the coldest temps I had ever started it in.
Now then, raising or curling the FEL was another story and ditto pressing the HST pedal to move the tractor. The noise sounded like the hydraulic pump was trying to pump frozen molasses with chunks of broken glass in it. Likewise the 3PH. I gave it another minute to warm a bit more and then raised the FEL. The FEL controls did not self cancel. If you start the FEL going up and release the joy stick the bucket kept going up till it hit the stop or you intervene to neutralize the control position.
I went on out and put a 1000 lb round bale on the FEL hay spike and another on the 3PH hay spike and delivered them to my Angus herd. Traction in the snow, even the drifts, was not a problem.
This storm and its frigid temps is past, there is less than 10% snow coverage of the pastures, with a general warming trend for a week or so and even overnight lows above freezing.
Next Wednesday is forecast for the low 70's. Ah, Oklahoma where the weather is never boring.
Oh by the way. The heating system for the cab on this 39HP tractor must have been designed by someone from Hokkaido or other northern Japanese location as with -5 F temp (-15 chill factor) the heater can literally cook you even if you are down to jeans and t-shirt. The cab is nearly a glass bubble and the heater/defroster will keep it pretty clean (rear glass has heating wires in it like cars have.)
If you are going to get seat time in arctic conditions I strongly recommend having a tractor that doesn't mind the cold and takes care of the operator heat and visibility wise.
Patrick
   / TODAYS SEAT TIME #770
Patrick
The owners manual should have 'cold starting and operating' instructions. It probably tells you to let the tractor run at or near 1500 RPM's for 20 to 30 minutes(to allow the hydraulics to warm up) in those conditions before operating the tractor.
You really should follow those instructions...........bad (expensive) things can happen otherwise.
2009 SolarTech Silent Messenger III Solar Message (A53117)
2009 SolarTech...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
2019 John Deere 5090R Tractor (A52384)
2019 John Deere...
2008 Nautica International RIB 24ft Cat Boat with T/A Boat Trailer (A51694)
2008 Nautica...
2014 International DuraStar 4300 4x4 Terex BT3063 63FT 15 Ton Crane Truck (A51691)
2014 International...
2012 UNVERFERTH 13-INCH REAR SPACERS FOR 10 BOLT HUB (A53473)
2012 UNVERFERTH...
