Most economical rpm
   / Most economical rpm #1
dmiletich
Member
New Holland TK100M
I have a 2009 TK100, which is the NH crawler. I use it primarily for disking, some on hillsides and some on flat ground. Since I am new to this tractor I am trying to figure out at what rpm do I get the best fuel economy. Has anyone with a similar horsepower(100)tractor got it figured out?
   / Most economical rpm #2
Go look at the tractor test data. If it was tested at the Nebraska Lab or at the European Lab, or if the engine that your machine has was tested on a tractor there, it'll give you a place to start. As a rule of thumb~ 75% of rated speed is in the ball park.
   / Most economical rpm #3
Where the PTO hits its standard RPM is a rule of thumb that has worked for us. For many tractors that is around 1800 RPM +/-.:thumbsup:
When working hard the engine does not need to lug and nothing is harder on an engine than a load on its PTO so most are designed to perform their best around that range when working hard.
While our 60 HP JD backhoe does not have a PTO and will turn 2500 RPM is sounds more happy around 2000 RPM's.
   / Most economical rpm #4
This is a hard question to get answered. Alot depends on what size disk your pulling, is it a 3pt lift or a pull type. What kind of ground are you disking, sandy, clay or good top soil. And how deep are you disking it. Like the OP said you can get a starting place at one of the centers he mentioned.
Jeremy
It is an 8'3" pulltype offset. The soil is generally good topsoil and the depth varies. I am doing in for primarily weed control. The parcels are from 1/4 to 5 acre properties. I am always moving from lot to lot so an 8'3" disk is really about the biggest I can use, and especially some of the places are real tight. The tractor pulls the disk like it's not even there so that is not a problem.
2020 CHEVROLET W4500 16FT REEFER BOX TRUCK (A53426)
2020 CHEVROLET...
2011 Manac 36245B30 43ft T/A Walking Floor Trailer (A50322)
2011 Manac...
UNUSED X-STAR 20' X 101" LOADING RAMP (A51247)
UNUSED X-STAR 20'...
PENDING SELLER CONFIRMATIONS (A53426)
PENDING SELLER...
UNUSED FUTURE BOX OF MISC RATCHET STRAPS (A51247)
UNUSED FUTURE BOX...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
