Grease Fitting Good..but won't take any Grease?!
/ Grease Fitting Good..but won't take any Grease?! #1
Johnny Glenn
Member
88 Ford 555B
Thanks for looking in - I've recently purchased an older machine, 88 Ford 555B, and going through it w/ fluids etc - I can't get about 6 fittings to take any grease. The fittings are good, I've taken them out and tried to clean the area behind the fittings but no luck as of yet. What's the trick? Thanks
/ Grease Fitting Good..but won't take any Grease?! #2
Where are the fittings? Heat may be an option to soften old grease, but on my front axle pivot, I had to remove the fitting that the zerks screwed into. There was an inch long channel full of hardened grease. A drill bit cleared it out. Every zerk may be different, but on my backhoe, it was the front axle and driveline zerks that were the bears. Outriggers can be tough too. It seems people don't grease them much.
/ Grease Fitting Good..but won't take any Grease?! #3
They make a tool for that.....here's the Snap on version to give you an idea....their's is pricey but has a pretty good description
Snap-on Tools
The cheaper versions are still around $35
/ Grease Fitting Good..but won't take any Grease?! #4
Hi well in the past i have seen this and it is usually caused by old hard greese, Try moving the joint that you are trying to greese while keeping pressure on the greese gun.You need someone to run the hydrolic system if the place you want to greese is moved by hydrolic means. You of course must be careful not to get hurt by the moving connection point i cannot sterss this enough !!! Or If you can isolate the part form the tractor try using heat, start with a propane torch, of course be careful not to catch anything on fire. If you could get the peice apart cleaning out the greese passage would work best. Try these but be careful.Good luck ,Jeff
Thanks for the advice - My problem areas are the front axle and the outriggers! I tried some heat on one of the front axle points but no luck. I shot some diesel in a few to let soak overnight but I'll try these suggestions tomorrow - thanks again.
/ Grease Fitting Good..but won't take any Grease?! #6
Tapping gently on the little ball in the end of the zerk also often cures the problem.
Heat is good also.
Last is to change the zerk.
/ Grease Fitting Good..but won't take any Grease?! #7
I've had some luck using penetrating oil, keeping the zerk wet, and letting it sit a day or 2. Tends to migrate well, better than most pure solvents.
I use ReleasAll, a Canadian product. It's much heavier than WD40, and works better for most of what I want to do - this type of problem included.
Best luck. D.
/ Grease Fitting Good..but won't take any Grease?! #8
If my fel is all the way down a few of my zerks won't take grease because of the pressure on the pin won't let it in.
/ Grease Fitting Good..but won't take any Grease?! #9
/ Grease Fitting Good..but won't take any Grease?! #10
As a proud owner of the snap-on rejuvenator, I recommend removing the zerk and using a drill bit to remove the old, hard grease (as mentioned above). If it still doesn't take grease, you'll have to remove the pin and clean it up.
/ Grease Fitting Good..but won't take any Grease?! #11
A trick I learned from an older mechanic, to get king pins in large trucks to take grease, was to dig out what you can, then fill the hole with penetrating oil. Screw the zerk back in, then put the grease gun to it. If you have a good gun, your exerting 6,000 psi on that fluid. It will usually find a way out, and the grease behind it. I'd say I've had a 90% success rate doing this.
On like the king pins, with a horizontal hole, you can make a half dam, or more.... Just smear a small dab in the hole, spray in the penetrate, then in quickly with the zerk.
Back in the day, when we restored hit & miss engines, we've jacked pistons out, using a grease gun. We'd take the head off, and make sure the valves were seating good, then make a makeshift headgasket, and torque it down.
Brazed a pipe sleeve to a junk plug that would fit, and neck it down for a 1/8" zerk, then pump the grease to it. 6,000 psi across the face of a 4" piston creates a lot of force..!! And all equal.
Of course this was back in the day of the bulk fill guns, and you could buy half buckets of grease at farm sales for a buck..., LOL...
/ Grease Fitting Good..but won't take any Grease?! #12
I've used Kroil before to loosen up stuff, but with grease it is usually all the oil has left the grease and you are left with a wax-like paste that doesn't budge. Once you disolve it grease plenty good and god back after you have used your machine some because now you want to flush out the penetrant so you don't have worry about thinning out your new grease:( Worst case is you have to disassemble and scrub to remove the caking if a lot of dirt or rust has gotten in:mad:
Thanks everyone for the tips - I had some luck on a few of them by letting diesel soak in overnight. Those top stabilizer zerks are tuff to get to. Wonder why there's no fittings for the bottom support/pin on stabilizers? Thanks again!
/ Grease Fitting Good..but won't take any Grease?! #14
I see Northern Tool supply has a 'kit' of 100 zircs for $20. Rather then spend time on trying to get a stuck zirc to work, just pitch the darn thing, screw in a new one and be done with it.
/ Grease Fitting Good..but won't take any Grease?! #15
I have one of the tools mentioned in the post. I am ont that impressed with it. I thinks it is ok for clearing zerks. I have not had any luck when there is hardened grease. I think heat or taking apart and cleaning best opton. I would try to move part to remove pressure from the pin.
/ Grease Fitting Good..but won't take any Grease?! #16
Here are a couple of tools available from MATCO, never tried them:
Vehicle Service, Miscellaneous Vehicle Service, Grease Gun Accessories | Matco Tools Online Tool Catalog
ZERK GREASE FITTING TOOL
匹lears grease from angled and straight fittings
Part#: GGA2 Price: $13.70
GREASE JOINT REVITALIZER
桧pens clogged grease joints and fittings, flexible hose can be attached to reach fittings in tight spots, and works on most standard automotive (Zerk) grease fittings.
俵sed separately from a grease gun
Part#: GFC2 Price: $66.25
/ Grease Fitting Good..but won't take any Grease?! #17
Shucks guys, for the price of zerks, trash them and install new ones!
Come on, every guy needs a reserve of misc zerks on hand. Much cheaper than replacing pins and sleeves.
To me, stocking zerks is like having oil, greese, hydraulic fluid and spare filters on the shelf.
/ Grease Fitting Good..but won't take any Grease?! #18
Zerks are rarely the problem. It's the hardened grease below the zerk that is a combination of grease, dirt, and metal. I have removed many zerks to clean out hardened grease below them. I always chuck-up the zerk in the grease gun and test it to make sure it is working. I don't think I've ever had one that did not work. They might get trash in them and not function well as a check valve, but most all zerks I've found will pass grease just fine.
/ Grease Fitting Good..but won't take any Grease?! #19
The zerks are not the problem here. It is dried up grease and wear debris clogging the hole. Penetrating oil, heat, physical disturbance, pressure on oil soak .... Great ideas.
larry
/ Grease Fitting Good..but won't take any Grease?! #20
Well, lack of maintenance/grease from previous owner is why there is old, dried out grease there in the first place, not a bad zerk. Best to remove grease zerk and manually clean hardened crud out of the hole and zerk itself.
Jinman, has described the good way to clear things up. I have done the exact steps with out having to replace zerks, but have had bad zerks on rare occations.
I also keep a good supply of assorted metric-standard size zerks. WAY cheaper-easier than pins, bushings to replace.
Ounce of prevention:D
UNUSED IRANCH MINI EXCAVATOR RIPPER (A60432)
UNUSED IRANCH MINI...
UNUSED FUTURE FT13 EXCAVATOR (A60430)
UNUSED FUTURE FT13...
Chevrolet 2500 Flat bed (A61306)
Chevrolet 2500...
2860 (A56857)
2860 (A56857)
Auger Mini Skid Steer Attachment (A59228)
Auger Mini Skid...
2022 Kubota LX2610SUHSD Compact Utility Tractor (A55315)
2022 Kubota...
