Getting gravel back on my lane
   / Getting gravel back on my lane #1
Gio
Nebraska
Massey Ferguson gc2400
Good news, Snow is melting. Bad news, 75% of my gravel is off of my 1/4 mile lane and spread 3 ft off either side of the road.
My lane is about ten feet wide then it drops off pretty quickly on each side. Does anyone have a good recovery method ?
I have a blade and a landscape rake but it may be hard to get a good even run with both sides dropping off the way they do.
Any thoughts would be appreciated.
GIO
   / Getting gravel back on my lane #2
Does either have the ability to "offset" or otherwise swing out to one side, well beyond the tractor tires? If so, I'd go with that. If neither, I think I'd opt for what ever one is the widest, and if the same, opt for the rake.
   / Getting gravel back on my lane #3
If it is down over the bank you might have to back down with your blade, so your tractor is perpendicular to the road, and pull it up onto the road. Its a slow process but works. Sometimes the easiest way is to get more gravel. Then next year keep your blade up a little when you plow until it gets frozen.
Another thought is to go rent one of those power brooms. I have heard they work really well for doing what you want to do.
Thanks everyone. My wife said a Rake and my two feet would be good exercise. I'll let her know I got better advice on TBN :D
   / Getting gravel back on my lane #5
I have found that if the gravel is only a thin coating you will bring more leaves and topsoil than it is worth if you use a tractor. You do not want to intrduce organic matter into a gravel drive as that then grows weeds and grass. I hand rake about 700' of drive. You need to go and purchase a quality rake and spend some quality time hand raking the shoulders before the grass starts growing. I try to get to mine just before the snow melts down to the green grass.
Happy Raking
Craig Clayton
   / Getting gravel back on my lane #6
Use a power rake, you know those paddle wheel powered by a two cycle motor, just like a weed whacker. they do a great job of getting the gravel off
grassy areas etc but leave the grass.
   / Getting gravel back on my lane #7
2X My dad said he did it this way and it worked really well also.
Good Luck ! :)
   / Getting gravel back on my lane #8
too bad you don't live closer, I have one. It's a Shindaiwa Power Broom. I'll add a photo to show along our road where I did one swipe and then took a picture so people could see what it does. It's still a lot of work but beats a rake! Maybe someone would have one of those big industrial rotary brooms for the front of a tractor in your area.
You wont notice so much extra gravel on the road but you'll notice none in your ditch or side of the road basically.
   / Getting gravel back on my lane #9
I had the same thing happen my first year with a 600' gravel drive. I opted to widen the driveway out a little on each side. The tractor worked great for spreading out the new gravel.
   / Getting gravel back on my lane #10
You could tell that rake would fit her hands too. Just don't tell her I said it. :D
2015 JOHN DEERE 624K WHEEL LOADER (A51406)
2015 JOHN DEERE...
2019 KUBOTA SVL95-2S SKID STEER (A52705)
2019 KUBOTA...
2 - BOXES (A53843)
2 - BOXES (A53843)
HYSTER H60XT FORKLIFT (A53843)
HYSTER H60XT...
Unused Delta Crash...
