Best RPM for fuel econemy and FEL work? (Piggy back thread from Kioti forum)
   / Best RPM for fuel econemy and FEL work? (Piggy back thread from Kioti forum) #11
Fuel costs less than rebuilding an engine. Lugging the engine is the best way to shorten its life. Keep the rpms up.
   / Best RPM for fuel econemy and FEL work? (Piggy back thread from Kioti forum) #12
The best RPM for fuel economy is 0rpm the best for FEL will vary greatly depending on what you are doing.
No matter what I never run anything under 1500rpm that's where I will start, and as soon as it lugs or starts to slow down a lot I`ll bump it.
For plowing I normally use around 1900-2100.
Moving dirt 2000-2500 depending how much, and what's in it.
I would say most of the time I run 1900-2300 and go above if I have a heavy item.
   / Best RPM for fuel econemy and FEL work? (Piggy back thread from Kioti forum) #14
Depending on how many hours you run your tractor a year (I don't think too many on here are currently running a working farm - If you were you wouldn't have time to be on here:laughing:) It probably only means several dollars a year and if your doing this for recreation Let 'er rip and enjoy yourself! The most fuel efficient thing to do is buy a townhouse and walk to the grocery store and work!:laughing:
   / Best RPM for fuel econemy and FEL work? (Piggy back thread from Kioti forum) #15
I personally like to vary the RMP on any motor. Maybe not while using it but each day I use it I'll adjust some.
   / Best RPM for fuel econemy and FEL work? (Piggy back thread from Kioti forum) #16
Sums up my philosophy, too. Never do anything under 1500 rpm, not even move the tractor. Any real work starts at 2000 rpm, heavy work starts about 2300 rpm. If they wanted you to run it slow, they wouldn't have geared the PTO to run at 540 rpm when the tractor is practically wide open.
   / Best RPM for fuel econemy and FEL work? (Piggy back thread from Kioti forum) #17
Too low RPM's makes my loader run to slow. Too high RPM's makes my loader run to "jerky". I run the RPM's that makes the loader work the smoothest with out lugging the motor.
   / Best RPM for fuel econemy and FEL work? (Piggy back thread from Kioti forum) #18
wide open is now 3200rpms.took the tractor to check the cows an ran it at 1500rpms.
UNUSED FUTURE FT-RP72 - 72" HYD ROCK CRUSHER (A52706)
UNUSED FUTURE...
2023 Chevrolet 1500 Silverado Z71 Crew Cab Pick-Up Truck (A59230)
2023 Chevrolet...
2014 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A60460)
2014 Chevrolet...
2011 Ford F450 Diesel with Just 156638 Miles (A56435)
2011 Ford F450...
PALLET OF JACKS AND JACK STANDS (A58214)
PALLET OF JACKS...
CASE INTERNATIONAL 5140 TRACTOR (A52707)
CASE INTERNATIONAL...
