One Way?
   / One Way? #1
DDT
Clay Center, Kansas
Kubota M6040/cab, BX25D, RTVX900
I found a 5' 3 point one way on a auction. Will my tractor pull it? I have no idea. I sure could plow gardens much faster for people. The owner told me it pulls like a 2 bottom plow....my tractor does that easy.
DDT
   / One Way? #2
DDT
Your Kubota L5740 has plenty of HP to pull it.
Is it wide enough to cover the tractor tracks and will you be able to plow deep enough? The one ways I pulled weren't designed for much depth.
When I was 6 I wasn't allowed to milk the cows but my job was to spray them with plenty of DDT to keep flies off. Boy could I make the barn fog.
   / One Way? #3
I missed the good old days. Pops used to get all misty eyed talking about the merits of lead paint.
   / One Way?
No it will not cover tire tracks, its 74" side walls to side walls. But its wider than a 2-14 plow. This is about 10" from the bottom of the spouls to the OD of the discs. I was hopeing it would get in 6 or 7" deep.
When I was growing up dad had a pull type and i do remember useing it some. It would put the spouls on top the ground. We used this for plowing rocky ground at the time.
Think it will work?
and you sniffing that much DDT I am glad your still upright.
(DDT) non-poisonious version....
   / One Way? #5
Depth will depend a lot on soil type and moisture content. Even if you had to hit it twice it would still be fast. I say go for it.
I've never seen a 3 pt oneway. We would sure like some pics if you get it.
   / One Way?
Well I got out bid...Went for 176.00
TRANSMISSION JACK & TRACTOR CYLINDER (A54757)
TRANSMISSION JACK...
2019 John Deere 5090E (A53314)
2019 John Deere...
200387 (A51247)
200387 (A51247)
Giyi 59" Mini Stump Grinder (A53316)
Giyi 59" Mini...
2018 ALLMAND BROS, INC. ALLMAND BROS, INC. (A55745)
2018 ALLMAND BROS...
2013 Ford F-550 Ext. Cab 4x4 Auto Crane 6406H 6,400LB 3 Ton Crane Service Truck (A55788)
2013 Ford F-550...
