What do the letters mean in the ford models?
   / What do the letters mean in the ford models? #1
sacsr
Kinston, NC
Yanmar 187D Terramite T5C Bush Hog D4-10
Looking at a 655C locally.....what does the "C" mean??
Series 6555 then a reverse 'C'
Serial AB08447
Backhoe 18-055
Just trying to decipher the info to see what year, etc this one is.
Any help would be appreciated.
   / What do the letters mean in the ford models? #2
The letter code is part of the models normally. The original, A, B, C, D, E,
Does that imply a year? Or a level or grade of tractor?? Different options?
Thanks
   / What do the letters mean in the ford models? #4
I think it's based on the date of manufacture. Different runs or series will get a different letter designation, beginning with "A". They'll run a particular series for a number of years then update a few things for the next series. Still the same basic unit, but with a few upgrades which don't warrant a complete model change.
Joe
   / What do the letters mean in the ford models? #5
Yup, the letters just imply a newer/updated model. So the C is newer than an A. For some reason, Ford never made a 655B.
As for the year, there should be a date code on the tag. Should be #a##a. If you post it, someone will decipher the exact build date
   / What do the letters mean in the ford models? #6
Serial AB08447
Backhoe 18-055
Ford uses letter for a particular model so that vehicle is identified uniquely. They give Vehicle Identification Number to each model. Except I, O, Q as it clashes with 1 and 0.
2019 Fontaine Traverse HT T/A 48ft. 41 Ton Hydraulic Dovetail Equipment Trailer (A52377)
2019 Fontaine...
HarbinGer Light Tower (A52377)
HarbinGer Light...
LINDE WELDER (A53843)
2015 MACK CXU (PINNACLE) (INOPERABLE) (A53843)
2015 MACK CXU...
2019 ExMark S-Series 72in Zero Turn Mower (A51692)
2019 ExMark...
2008 VE 500 BBL FRAC TANK (A53843)
2008 VE 500 BBL...
