Anybody know what this is?
   / Anybody know what this is? #1
jake98
Dingmans Ferry PA
53 Cub, 70's JD 410, Kioti 25hst
It was with my uncle's welder when I got it.
Heater? Battery tester?
It has a ribbon serpentined in it.
   / Anybody know what this is? #2
Well a photo might be worth 1000 words, and having it in my hands would be worth 1000 photo's, but if I had to guess, it is a load tester, or part of a battery tester, you still need a voltmeter to measure what happens to a battery when this resistive load is placed across it. Assuming the "ribbon" is a piece of nichrome wire
James K0UA
   / Anybody know what this is? #3
On second though, any chance there are diodes in that box?, the ribbon comment made me think resistive load, but if there are diodes, then this could be a rectifier for the AC welder, to make DC?
James K0UA
   / Anybody know what this is? #5
I can only see 2 terminals on that thing, so cant be a rectifier assembly and maybe we can see the edge of the nichrome ribbon wire, I am not sure. Take an digital ohmmeter and measure between those 2 terminals. and tell us what you got.
James K0UA
   / Anybody know what this is? #7
A rectifier (diode) only has two terminals, the anode and cathode, so don't see how the mystery device rules that out with it only having two terminals. A rectifier bridge has four.
Doesn't appear from what we can see to have enough heat sinking to accomodate a welding rectifier....
Curious to know about the welder it came with also. Perhaps it is a way to reduce current to a lower value than the lowest setting on the welder..???
We need to know more!
   / Anybody know what this is? #8
I am guessing it is a rod heater.
Bill
I think it just has the wire ribbon in it, I'll look closer. The ground clamp on it has me confused unless it's a battery tester missing a lead. The welder was a Lincoln ac/dc 225 but it's not the vintage of this thing.
   / Anybody know what this is? #10
Have you ruled out a flux capacitor?
2002 Bobcat 763 Compact Skid Steer (A56438)
2002 Bobcat 763...
2018 CATERPILLAR 12M3 MOTORGRADER (A52709)
2018 CATERPILLAR...
2018 Chevrolet Impala Premier Sedan (A59231)
2018 Chevrolet...
iDrive TDS-2010H...
Pull Type ATV Sprayer (A59814)
Pull Type ATV...
2014 Lincoln MKS Sedan (A59231)
2014 Lincoln MKS...
