Tires what size wheels and tires for a Yanmar 186D
   / what size wheels and tires for a Yanmar 186D #1
Texas Cowgirl
Yanmar 186D
I recently purchased a Yanmar 186D. It has a 15" rim with car tires on the front. This only allows for wide turns. What size wheels and tires are correct for this tractor?
   / what size wheels and tires for a Yanmar 186D #4
Oops I was way off sorry about that folks. :eek:
   / what size wheels and tires for a Yanmar 186D #5
Those are huge front tires for a 4wd. If the rears are sized accordingly, you will have to change them also, to prevent damage to the front wheel drive.
   / what size wheels and tires for a Yanmar 186D #6
Yanmar Tractor Tire Size Comparison By Model
Hth! 1510D is I believe the equivalent tractor btw I see the 186D isn't listed sorry and welcome! :)
That confused me too. Just one of the minor differences between the built-for US YM186D, and the Japan-market YM1510D.
I need a low profile to get under my orchard trees so the US version on 16" wheels is a better choice than the 1510's 18" wheels.
The only other differences I have noticed are a 2-speed pto with internal overrun clutch, and a big external hydraulic filter. Maybe the air filter? These are essentially the same tractor with different options bolted on.
Oh and a minor point on front tires: 6-12 is what belongs on there to go with 9.5-16 rear. The common US size 6.00x12 is taller and stresses the 4wd, since this larger tire goes farther per revolution.
   / what size wheels and tires for a Yanmar 186D #7
According to my calculations based on firestone ag numbers of 69" circumference on the 6-12 and 98" on the 9.5-16 the front to rear ratio would have to be in the 1.45 to 1 + or - range to be correct. Anybody have that ratio?
   / what size wheels and tires for a Yanmar 186D #9
The wheels for the ag tires are 8X16 and 5X12.
There were also optional wide turf tires 31X15.5X15 and 23.5X8.0X10.
The wheels for these were 10X15 and 6X10.
There were also narrow turfs which were 9.5X16 and 6X12.
The wheels were 8X16 and 5X12.
Rodger Scotty wrote a really good piece about tires back when we first came over. Might be worth looking for it in the old posts.
Chris
   / what size wheels and tires for a Yanmar 186D #10
On my 276d it took a long time for the gear oil to work it's way thru. I'd fill it.. let it sit. Check the dipstick... fill it again.. let it sit, etc.
OOPs. wrong thread.
Selco V5-HD Vertical Hydraulic Baler (A55851)
Selco V5-HD...
2018 Chevrolet Tahoe SUV (A55853)
2018 Chevrolet...
UNUSED FUTURE 12" HYD MINI AUGER (A57193)
UNUSED FUTURE 12"...
Booster Cables (A55852)
Booster Cables...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A54814)
2015 Peterbilt 320...
Magnolia Trailer with Adams 25 Ton Fertilizer Tender (A57024)
Magnolia Trailer...
