Insulation prices
   / Insulation prices #11
I also saw the article on using spray and bat insulation together. Looked very promising, but did not read it in detail. One thing that stuck out though was that the thickness of the spray foam was important to control condensation from occuring in the bat insulation. And of course that depends on your local weather conditions.
The other thing about spray foam and diy. I checked the internet costs to do the spray foam myself and also had the local contractor bid the job. Turned out the local contractor charged something like 3 cents more per square foot, but installed 3 times the thickness the diy foam would do. So be sure you give the local contractor the chance to at least bid the job before you commit to diy.
   / Insulation prices #12
Hey mojoinco. They did install a layer of some kind of thin insulation or reflective stuff between the studs and metal.
So you have metal siding or roof? Usually its studs, followed by 1/2" plywood sheathing, then a barrier like tvek or a thin insulation, then the siding. If you have a thin insulation barrier between the plywood and siding thats a good thing and will reduce the air infiltration. Its the other areas where the materials meet that allow air in..
One comment and personal experience, I had the option to do this 15 yrs ago when spray foam was just coming out but opted (due to timing and cost) to use batt insulation. Well, we have a tight house, but still have airleaks / infiltration especially around the rafters/roof line area and other areas that would have been eliminated if we had gone the spray foam route.
I wish looking back I would have done the spray foam, and what you need to consider is this is the last time you will be able to do this realistically. It also sounds like you are in this place for the long term, so I would bite the bullet and use foam or some combination of foam and batts. You will reap the benefits in years to come.
Carl
   / Insulation prices
Carl
Its metal siding with no plywood. It has the thin insulation and then metal.
   / Insulation prices #14
I would be concerned about the fiberglass insulation turning into a warm bedding place for mice in the barn/shop. The slab-on-grade construction that is frequenly used lacks ratwalls and blocks above grade, the insulation is right down by the ground where it is easy for the mice to get into.
   / Insulation prices #15
An option I am using is polyiso foam. It's the (usually) brownish yellowish foam used by roofing contractors. Around our area it is sometimes available used in various thicknesses. The used stuff is in pretty good shape with a few large screw holes.
It usually goes for about $5 for a 4x8 sheet. The insulation value is about 50% better than the foam you get at the big box store and it is much easier to work with (cuts very clean). After you install it you can spray can foam the holes. I put 3-1/2" in my basement and have almost enough to put 5" in the walls of my 40x48 pole barn I'm rebuilding.
If you call some commercial roofing places you might find a source.
   / Insulation prices #16
for the house. i would vote for a professional to come in and spray foam the entire house, walls and ceiling. and would most likely go with an open cell foam. to allow the walls and ceilings to breath a little bit.
if you doing insulation yourself in house. then most likely it would be the old rolled insulation. with vaper barrier. its cheap and it works.
for the shed. i would vote for a couple layers of hard board insulation, and at least one layer that has foil backing. and as i put the hardboard insulation, use a closed cell spray foam for me (i need to buy stock in the company way i used it last few years) great stuff red can with yellow cap. and use foil tap over all seems. the hardboard insulation can be cut out with a utilty knife or a steak knife if need be. and then patched backup. if a mice gets a hold of it. that and it tends to be more easier to tell were the blasted roadents came in through because you can see a trail of foam.
i wanted proffesional to come out and do the garage. but it automatically required that i put sheet rock or something over the spray foam. in order to meet code.
   / Insulation prices #17
I just insulated my basement ceiling and some walls. I had it blown in. The guy offered me an incredible deal to do my attic while he was here already doing the basement.
625 sq. ft. of 2X6 Joists
300 sq. ft. of 2X4 walls
700 sq. ft. of attic (R-39)
It all cost just about $1100. That comes to an average $0.68/sq. ft.
2004 Dodge Ram 1500 Crew Cab Pickup Truck (A56858)
2004 Dodge Ram...
2007 Hyundai Santa Fe SUV (A55973)
2007 Hyundai Santa...
2023 Top Air ATV 200 Gallon Pull Type Sprayer with 30ft Booms (A56435)
2023 Top Air ATV...
2017 Genie GTH-5519 (A53317)
2017 Genie...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
