Changing Outer Drive Shaft Seal (RF 1310)
   / Changing Outer Drive Shaft Seal (RF 1310) #1
kc5sii
Oklahoma
Ford 1310, '72 Cub 1410, Swisher 66" ZTR -w- 60" Trail Mower.
I'm going to change the right front outer drive shaft seal. 2 Questions first.
1. I have the part. Apparently, the direction the seal is installed has changed. However the data sheet included with the part is in Japanese. a. does anyone here read Japanese or b. Can someone clear this up for me? I'd hate to install a $35 part backward and have to make it it a $70 part!
2. It appears, from the service manual, that once you remove the King pin bolt Part #19 and the steering arm, the reduction gear housing #10 will drop out. How much of a pain is it to get the shaft #11 to line back up when reinstalling?
Thanks in advance.
Dave
   / Changing Outer Drive Shaft Seal (RF 1310) #2
Sorry I don't read Japaneese. Could you post a pic of the seal. You can usually tell by looking at it. Is it a grease seal or an oil seal. Where are you getting the # you are refering to.
Bill
   / Changing Outer Drive Shaft Seal (RF 1310) #3
Lip to lube.
The seal is supposed to hold Lube Oil in the wheel gear compartment. The differential shaft seems to be a separate compartment.
Looking closer at it, I think the captions with Arrows on the top are the Japanese versions of the text on the bottom. I'm still not sure it the metal side goes up or down.
See attachment.
  • Frnt Seal.pdf
   / Changing Outer Drive Shaft Seal (RF 1310) #7
It says to mount the iron sheet side facing the muddy water side. In other words, the metal side faces out.
   / Changing Outer Drive Shaft Seal (RF 1310) #8
You install a grease seal with the metal cup facing the grease?
A lot of grease seals are installed so the grease can push out through the seal. They are more to keep dirt out than grease in. If you have the lip facing the grease and pump it full of grease you can push the whole seal out.
Bill
So the flat metal part would go up assuming the Gear oil is toward the bottom. I guess that makes sense. I just wanted to bounce it off the experts before I did the work. The cutaway is less than helpful.
It looks pretty straight forward. It took me a while to figure out what holds the whole assembly together. Three cups of coffee and the I&T manual.
Dave
Done. Piece of cake. Thanks!
2014 DRAGON 500 BBL FRAC TANK (A53843)
2014 DRAGON 500...
2017 Chevrolet Colorado Crew Cab Pickup Truck (A53422)
2017 Chevrolet...
2004 Freightliner FL112 Cab & Chassis (A47384)
2004 Freightliner...
2015 JOHN DEERE 250G LC EXCAVATOR (A52705)
2015 JOHN DEERE...
2018 MDB T5E MDB DISC MOWER (A51247)
2018 MDB T5E MDB...
2012 MACK WINCH TRUCK (A53843)
2012 MACK WINCH...
