Bought a H 106 Vermeer Automated Rock Picker
   / Bought a H 106 Vermeer Automated Rock Picker #1
sweettractors
Advertiser
Central Kentucky
JD 6403 CHA-JD 3130 CHA
We Bought a real nice Vermeer H 106 Automated Rock Picker Sat. When we go through it, we will sell it waaay under market value. Stay tuned. Ken Sweet
   / Bought a H 106 Vermeer Automated Rock Picker #2
The H-106 Vermeer Rock Picker was made by Haybuster and you will want to get the repair parts for it from a Haybuster dealer. The down side of the h-106 unit is it is almost 14" in transport position. The newer Haybuster 3106 is easier to transport. Check the auger teeth. They need to be at least 2" long for the unit to work properly. CCM is an authorized Haybuster dealer.
We will remove the gathering arm and reduce transport width to 9 ft outside to outside of tires. Auger teeth are 3-4 inches best I can tell in the field. Once we get it in the shop, we will thoroughly check it out. Ken Sweet
   / Bought a H 106 Vermeer Automated Rock Picker #4
I wonder if the H-106 is set up for open center or closed center hydraulics.
Works on all tractors except the older John Deeres, like the 3020 and 4010 etc. Ken Sweet
   / Bought a H 106 Vermeer Automated Rock Picker #6
Ken you might want to study the difference between open center and closed center hydraulics systems.
You need to read page 35 of the 106 operators manual.
Mark, I know you are trying to help and I thank you for that. I already have the original owners manual and knew the difference open and closed center hydraulics before you were born. I amy may be hollering at you for some parts, once we get it in the shop and run it. Stay tuned. Ken Sweet
1065 (A53342)
1065 (A53342)
2019 Ford Explorer AWD SUV (A55758)
2019 Ford Explorer...
2021 CASE 580SN WT (A47477)
2021 CASE 580SN WT...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55301)
NEW HOLLAND 706 30...
2021 JOHN DEERE 648LB GRAPPLE SKIDDER (A52705)
2021 JOHN DEERE...
