3 1/2 in bore cylinder on wood splitter
   / 3 1/2 in bore cylinder on wood splitter #1
rednck3550
has anyone used a 3 1/2 inch bore cylinder with 1 3/4 inch rod on a wood splitter?i have 11 hp and 16gpm,how would this do with this size cylinder?i have a feeling its gonna be fast but no power,any suggestions?buy new cylinder?use what i have?i dont know what to do.has anyone evr used one setup like this before?thanks for the help in advance:confused::confused:
   / 3 1/2 in bore cylinder on wood splitter #2
3550, yes I have a splitter with a 3.5 dia. cyln. and 1and 3 guarter ram and it works out real well:thumbsup:Dave
   / 3 1/2 in bore cylinder on wood splitter #3
That sounds like about what my Swischer? (spell) is and its rated at 22 tons. Plenty of power for the tough elm here in western Ks.:)
im repowering my old splitter but it has a single stage pump and its slower than molasses on a cold day,so i got a 11hp engine and 16gpm 2 stage pump but wasnt sure bout the cylinder,i live in wv where all the oak and hickory and locust is at and thats primarily what i burn,do you see me having any problems with spliiting power with this cylinder?ive had this splitter for so long and use it so much i just realy dont wanna do this a second time.i think it will be ok if i dont try to split down the middle of a 24inch piece f hickory or locust...what will the cycle time be?should it be pretty fast as well as fairly powerful?
   / 3 1/2 in bore cylinder on wood splitter #5
You only have about 12 tons of force with a 2 stage pump..
Your cycle time will vary . At 16 GPM,
6.4 ips
8.5 ips
at the lower 4 GPM, it will be slower.
1.6 ips
2.1 ips
   / 3 1/2 in bore cylinder on wood splitter #6
Here is the specs on my splitter. Never had any power problems.
7 HP Briggs & Stratton 875 Series engine
22 tons of splitting force
4" x 24" cylinder
11 gallon-per-minute pump for minimum cycle time and faster splitting
Heavy-duty 2-stage pump provides maximum splitting performance
   / 3 1/2 in bore cylinder on wood splitter #7
3550, I,m using a HF 6.5 horse motor with a 11 gpm 2 stage pump and cycle time is about 13 seconds out and just a tad slower back but very useable.It,s never failed to split red oak and I even put a twist in my wedge so no complaints power wise:DDave
ok everyone thanks for the input,i think im gonna try the cylinder i have first and if thats not good enough i'll just switch to a 4 in cylinder.hpefully it will satisfy me,cause i hate to do things twice lol.but i use it enough that i gotta be able to split what i need to,so i'll get it the way i want it eventually.once again thanks for the info everyone
   / 3 1/2 in bore cylinder on wood splitter #9
4" x 24" cylinder
The manufactures are fudging the figures on your system. They do it all the time. The are assuming that the 2 stage pump is pumping at 3000 psi, and even at that, they add a couple tons.
   / 3 1/2 in bore cylinder on wood splitter #10
Log splitters are always faster in the retract mode.
2008 Genie GTH-844 Telehandler (A57453)
2008 Genie GTH-844...
2021 VERMEER S925TX STAND ON SKIDSTEER (A52709)
2021 VERMEER...
Copper Horse Weathervane (A57454)
Copper Horse...
John Deere 3025E (A53317)
John Deere 3025E...
Unused 2025 CFG Industrial MX12RX Mini Excavator (A59228)
Unused 2025 CFG...
3-D Printers (A56860)
