Jinma 284 3 point question
   / Jinma 284 3 point question #11
I too was having the same issue. I just cleaned out the little valve and replaced it.
When I adjust the valve to allow it to raise, it won't lower unless I loosen the valve. Even if I fine tune it to the point where it will barely raise, I can watch it slowly drop. If I tighten the valve a little bit more, it holds its place BUT it is too tight for it to be raised.
Does that indicate that I should replace the seals on the 3-point cylinder with the kit I bought from Affordable?
   / Jinma 284 3 point question #12
Do you have a implement on the 3 point? It will not usually drop without a item on the 3 point.
Chris
   / Jinma 284 3 point question #13
When I adjust the valve to allow it to raise....
That's not what it's for. The lift raises hydraulically, but is a gravity drop. The valve only controls the rate of fall, not lift
//greg//
   / Jinma 284 3 point question #14
Yes I have a heavy back blade on it now. So Greg, if I adjust the valve to have a reasonable gravity drop time, the whole issue of it dropping on its own is a whole separate problem?
I noticed that if I turn the valve half a turn counter-clockwise (therefore tightening the valve), it prevents the 3 point from slowly dropping down.
   / Jinma 284 3 point question #15
Yes, and a very common one on the 200 Series Jinma at that. It's typically caused by raising the rear lift too high; either with the lift lever (Jinma claims that's what the thumbscrews are for) or by bouncing down the road with an implement held too high. The higher the lift, the farther the piston travels in an open-ended cylinder. The cylinder isn't long enough to accommodate full piston travel, and - at the extreme - the piston O-ring and wiper(s) extend past the end of the cylinder. The act of lowering the lift retracts the piiston, at which time the O-ring and wiper(s) are damaged. From that point on, leakdown occurs.
On some Jinmas, there's an internal stop bolt that's also supposed to prevent over-extension. The operative word is "some", so there's a chance you don't have one. And it's also been found on some that do, that the stop bolt was adjusted wrong (in that it still didn't stop the over-extension in time).
Knowing how common the problem is, I doubt there's a Jinma dealer in the world that doesn't carry a shelf full of the lift cylinder repair kits. Not an expensive or complicated job, just time-consuming and messy.
//greg//
   / Jinma 284 3 point question #16
Thank you for your insight Greg. I'm glad I purchased the kit from Affordable and I'll fix this up as soon as it gets above freezing.
   / Jinma 284 3 point question #17
Since you're dealing with Tommy already, he might be able to shed some more light on the internal stop bolt feature. With luck you'll learn whether or not your tractor has one in the first place. And if it does, whether there's enough adjustment in it to prevent this from happening again.
//greg//
   / Jinma 284 3 point question #18
If closing the valve that controls lowering speed prevents it from dropping, it is not the piston seal/rings. The knob will not affect that. It is in the valve that controls lifting and lowering, it is not sealing in the centered position or not centering completely. Closing the knob holds the oil in the cylinder, regardless of the control's position. leaky piston seal will allow the 3 point to drop regardless.
   / Jinma 284 3 point question #19
   / Jinma 284 3 point question #20
Okay so it appears that it might be the hydraulic lift valve then. Is there a rebuild kit for this? I can't find anything on Tommy's web site except for a new valve assembly.
MASSAGE CHAIR (A58214)
2017 Jacobsen 3551 HOURS (A56859)
2017 Jacobsen 3551...
2012 INTERNATIONAL DURASTAR 26FT NON CDL BOX TRUCK (A56138)
2012 INTERNATIONAL...
2024 CATERPILLAR 305 CR EXCAVATOR (A60429)
2024 CATERPILLAR...
Dvorak Model 3072A Hydraulic Ironworker S/A Towable Trailer (A59228)
Dvorak Model 3072A...
2013 Ford F-450 4x4 Crew Cab Little Beaver LS300 Drill Rig Truck (A59230)
2013 Ford F-450...
