Insulate Behind Air Duct
   / Insulate Behind Air Duct #1
dieselscout80
South Carolina
New Holland TC45DA
I need to put insulation behind the air duct shown in the attached pic.
What is the best way?
The easyest seems to be spray foam, but small cans are going to be pain.
I tried adding a hose to the small cans to reach behind the duct and that seems to kinda work, butto fill the 24' of 10"x16" cavity is going cost a lot.
Do they make spray foam in larger cans?
   / Insulate Behind Air Duct #4
I bought some bags of styro-foam crumbs that were packaged as cement block basement wall insulation. Idea is to pour into the top of the wall and let the crumbs fall to the bottom. The walls do feel warmer. Maybe you could use that. Say staple a 2 ft strip of plastic to the bottom of the studs, stuff that full, add another strip of plastic, stuff that, etc.
The studs are getting fiberglass batts with plastic between the block and the batts.
I'm just trying to figure out how to insulate the floor joist cavity behind the air duct.
I called a spray foam dealer and he said that it would be a waste of my money for him to come out and do this small area. He recommended that I get on Ebay and buy some 2 part spray foam like tiger foam. He said it was cheaper on ebay. He also told me to get a couple of spare guns in case I had to stop for a while.
I like it when a company/contractor doesn't try to waste my $$$.
   / Insulate Behind Air Duct #9
How about some reflectix insulation. Only a 1/4"-3/8" thick. Is that a return or supply duct?
   / Insulate Behind Air Duct #10
I am finishing up the same type of project in my basement. Framed and finished. For my floor joists space, I hired a service distributor to come in and spray my entire band of joist area with Icynene (Icyneneョ Spray Foam Insulation & Air Barrier Material ? Energy Smart Foam Insulation) and it is well worth the money and planning. I then had my CMUs filled with the same type of foam from the outside by drilling a hole in every other cell and filling with insulation. On the inside, between the CMUs and the stick framing, I placed a sheet of R6 blue sheet insulation, then filled the framing with R11 fiber.
To answer your question, foam doesn't come in large cans that I am aware. Again, the Icynene product will serve you well along the open areas of which you speak. Maybe you can make out the installation from a few pics I posted below. I'd also consider cutting the blue sheet insulation and piecing it in behind tha duct.
Prime and paint the drywall before the ceiling and trim. :D Works very well for speedy painting.
I'm wrapping up my suspended ceiling this weekend, electrical, ceiling fan, air diffusers, and all. Next is the flooring (as my walls are already easily painted.
If I never touch another piece of drywall for the rest of my life, it will be too soon. Dang what a DIY chore.
2014 TROXELL KILL/TRANSPORT TRAILER (A50854)
2014 TROXELL...
2023 TAKEUCHI TL10V2 SKID STEER (A51242)
2023 TAKEUCHI...
2013 Ford F-150 XLT - EcoBoost, Blown Engine, Good Parts Truck (A51039)
2013 Ford F-150...
John Deere 6105E Tractor, 105HP, 4WD, Suspension Seat, A/C, 3 Rear Remotes (A51039)
John Deere 6105E...
2018 Vermeer D23X30 S3 Navigator Directional Drilling Machine (A49461)
2018 Vermeer...
2002 KENWORTH W900 TRI AXLE (A50854)
2002 KENWORTH W900...
