Engine Block HEATER
   / Engine Block HEATER #1
castiman
oswego,ny
jd 2520,jd x530
Can anyone tell me anything about a engine block heater for a 2520. Is it hard to install, and can you leave it plug in a few days if you don't need to use your tractor. Also if I feel that I can't install it myself,can someone that has tell me about how long it should take the dealers service department too.
   / Engine Block HEATER #2
Not sure about your specific model but when I got mine it was only $50 installed (1999). I had a short and had to replace it and it just screwed out like a spark plug, then I screwed the new one back in. I think it replaces one of the freeze out plugs.
Re leaving it on - don't think they come with a thermostat so when it's plugged in it's heating. Shouldn't be a problem when it's cold but it's kind of unneccesary. Even putting it on for 30 minutes makes a huge difference in starting. I have mine on a timer so if I have to plow in the morning it's warm, if not it kicks off in about 2 hours so it's not on 24/7.
   / Engine Block HEATER #3
No. At least the ones I've used over the years have no thermostat. Plug'em in, they're on. Pull the plug, they're off. And at 500w or more each, that makes the electric meter spin a little more than I care for. So if you go that route, cough up an extra $20 for a 3-wire timer switch. That way you can set it to energize your block heater a few hours before you typically intend to use the tractor, and let it sit cold the rest of the time.
//greg//
   / Engine Block HEATER #4
   / Engine Block HEATER #5
45 minutes is plenty enough electricity to send through it. After that, you are just paying the electric company. One of the best darn options for a tractor, imho. Wouldn't be in cold weather without one.
   / Engine Block HEATER #6
I put in my own on a 4110. I don't think it is much different than your tractor. Took me about an hour. (Course, i'm old and slow) I agree with the others on unplugging. To solve that I bought a remote controlled plug at Ace Hdwe. $25 and I turn it on and off from my Kitchen. I think I am at the limit for distance-about 130 feet--but it works great.
   / Engine Block HEATER #7
2520 Block heater. Part #AR87167 $73.00. About 1/2 hour to install. Probably have it done for $100.
   / Engine Block HEATER #8
The dealer threw one in for no charge when I bought my JD 4120 about 5 years ago so they cant be too expensive. As far as keeping it plugged in, like others stated, that is a big waste of electricity but more importantly, it will result in premature failure of the heater (they are good for only so many hours so it dont make sence to use them up sooner than necessary). I know this because we have a Cat diesel gen-set at work that the block-heater is left on continuously all winter and we rarely get more than a couple winters out of a heater. For my tractor, 45 minutes is enough, 30 will do in a pinch, but I usually go for an hour or so. The block heater is probably the smartest thing you can add to a diesel used in cold climates, because it reduces engine wear, and lets you work the machine hard immediately after cranking it over. Also, depending on your situation, you may not need to waste any cash on timers, remote switches, etc.. I take a 4wd truck to work each morning, which will make it thru up to 24" or so of snow, so I dont bother plowing until I get home from work (that also lets me sleep in a little longer each morning). When I get home from work and pull the truck in the barn, I plug in the tractor. Next, I go in the house and eat a nice relaxing dinner with the family. After dinner, I go out and plow the driveways, the tractor now perfectly "warmed up". I do keep a gas tractor with a plow on it as a backup. That also gives me an option, with no need of a block heater, for getting rid of more than 24" of snow in the morning.
   / Engine Block HEATER #9
Even in the coldest of days, my 2320 starts likes its a summers day after the block heater is plugged in. Very good option. I tried starting the tractor when she's cold, and it just labours for too long. I just know I am straining the engine.
If you know when you need the tractor (daily chores), I suggest putting the block heater on a timer. If you just need the tractor when you need it, wire a plug for your block heater to a switch that you can access easily.
Around here, I have seen apartment buildings each having a "parking spot" switch in their apartments. Depending on the weather, you flick the switch on an hour before you go out. My sister had a block heater, battery blanket and an actual heater inside her car all hooked up. She hated a cold car.....
If you leave the block heater working all the time, you can wear out the heater and you can prematurely age the oil your heating, and electricity is just too expensive.
   / Engine Block HEATER #10
You got two outa three right. Their lack of thermostatic control is hard on both the heater and the electric bill. But block heaters heat coolant, not oil
//greg//
2019 KENWORTH T680 TANDEM AXLE SLEEPER (A54313)
2019 KENWORTH T680...
2016 CATERPILLAR 277D SKID STEER (A52705)
2016 CATERPILLAR...
2008 OSHKOSH FRONT DISCHARGE CONCRETE TRUCK (A54313)
2008 OSHKOSH FRONT...
2024 New Holland Skid Steer (A52377)
2024 New Holland...
2018 DRAGON 150 BBL ALUMINUM TRAILER (A53843)
2018 DRAGON 150...
2018 KENWORTH T880 DAYCAB (A53843)
2018 KENWORTH T880...
