7/8 to 3/4 ports
   / 7/8 to 3/4 ports #1
rednck3550
hi there i have a 4 1/2 in bore cylinder that im putting on my wood splitter and its got 7/8 ports but i have 3/4 line from the valve,can i adapt my 3/4 line to 7/8 to make this work and will it hurt the capability of the system to do so?the cylinder is a prince 3000 psi 4 1/2 inch bore with a 2 inch rod and 30 inch stroke.any input would be great,thanks
   / 7/8 to 3/4 ports #2
You'll have to be a little more specific on the port type. I'm guessing you've got NPT (pipe threads) with a 1/2" NPT port on the cylinder and a 3/8" NPT male hose end??? Those would measure close to 7/8" and 3/4" if that's how you determined the size. If that's the case, you can simply install a bushing into the cylinder port to reduce it to 3/8" NPT.
   / 7/8 to 3/4 ports #3
You left out the most important number....pump flow....
wont hurt anything, unless your pump flow is so high that 3/4" is restricting (over 20ft/sec in fluid velocity) and creating heat.....but it would take at least 22gpm from pump (with a 2" rod that will make 27.5gpm return flow when retract)....
   / 7/8 to 3/4 ports
ok my cylinder is prince #4hl55 it has 7/8 14 ports and my pump is 2 stage 16 gpm.basicly with what i have i can run 1/2 in or 3/4 in line but the cyl has 7/8 ports and im not sure if they make adapters from7/8 to 1/2 but i know they make 7/8 to 3/4 so i thought of going with 3/4 lines.just tryin to figure out the best way to do this.any help please would be appreciated
   / 7/8 to 3/4 ports
ok since it can be adapted,can it be adapted to 1/2?or do i have to use 3/4 line?not only am i trying to figure out how to adapt but im trying to figure out which line size to use.do you think that 3/4 would be better than 1/2 and why?would there be any performance problems with 1/2?
   / 7/8 to 3/4 ports #7
Look through the chart for the size you want. You may have to use two fittings to down size.
   / 7/8 to 3/4 ports
also what parts do you use to adapt 7/8 ports in cylinder to 1/2 or 3/8 line?sorry bout all the questions i just dont know that much bout this stuff other than just very little basics.thanks again
   / 7/8 to 3/4 ports #10
Your 3/4" hose is absolutely adequate for your splitter. What you have is a -10 O-Ring Boss port on the cylinder. I'm not sure what is on the end of your hose. Is there an O-Ring on there or did you have thread sealant before? Lets identify your hose end and we can tell you which adapter you need.
PEMBERTON LR129-1123 RAKE ATTACHMENT (A53426)
PEMBERTON...
2011 WESTERN STAR 4900 (A53843)
2011 WESTERN STAR...
2017 FREIGHTLINER M2 106 (A53843)
2017 FREIGHTLINER...
2006 John Deere HPX Gator 4x4 Utility Cart (A50324)
2006 John Deere...
MCELROY COOL PACK 20 (A53843)
MCELROY COOL PACK...
2013 MACK CXU613 (A53843)
2013 MACK CXU613...
