What is the correct thermostat temp for a 2000 diesel?
   / What is the correct thermostat temp for a 2000 diesel? #1
jachamar
Burlington,NC
The operator manual it say 168.The I&T and the Service Manual (905 pages) say 188
Thank you in advance
   / What is the correct thermostat temp for a 2000 diesel? #2
Most engines run in the 175 to 190 F range. overheating involves air flow through the radiator and grass clippings.
Winter can be a problem for engine heating, just block off half of the radiator.
Thank you for you quick replied .The dealer is trying to sell me the 168,but I prefer a little higher than lower ;:mostly in a Diesel.I guess I'll go for the 188:D
   / What is the correct thermostat temp for a 2000 diesel? #4
looks like the 188 is for a gas engine. taken from the cnh website
19 AR D8NN8575AA THERMOSTAT Thermostat Assy., Water, Standard, 168�, Start Year: 01/01/1965
19 AR D8NN8575CA THERMOSTAT Thermostat Assy., Water, 172�, Start Year: 01/01/1965
19 AR D8NN8575BA THERMOSTAT Thermostat Assy., Water, 188�, Gasoline/Petrol, Start Year: 01/01/1965
20 2 E9NN8255AA GASKET Gasket, Water Outlet Connector, Gasoline, Start Year: 01/01/1965
   / What is the correct thermostat temp for a 2000 diesel? #5
Why not see what temperature range the engine runs in now and in the heat of the summer.
Remember that the T-stat sets the lower operating temperature. Too cold and it is inefficient and the oil will never be in the green range. hot at normal loading is good, too hot not so good.
   / What is the correct thermostat temp for a 2000 diesel? #6
yep... those diesels don't like being cold.
soundguy
   / What is the correct thermostat temp for a 2000 diesel? #7
when I got one for my 4610, the new holland dealer asked me if it had a cab. so looks like if you have a cab, it gets the hotter one so you have heat. otherwise its the 168. mine runs about 1/4 of the way into the green range on the temp gauge.
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A51692)
iDrive TDS-2010H...
JOHN DEERE 560M (A53084)
JOHN DEERE 560M...
2015 Infiniti QX60 SUV (A50324)
2015 Infiniti QX60...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A53473)
2019 Krause...
2025 K732 UNUSED Flower Bed (A53117)
2025 K732 UNUSED...
2004 JOHNSTON STREET SWEEPER (A54313)
2004 JOHNSTON...
