Erradic Lift Cylinder Movement
   / Erradic Lift Cylinder Movement #1
tbyrd1960
JD 40 Standard, Ford 4400 TLB
I have a 1965 Ford 4400 TLB. The backhoe on my 4400 is a model 753. All works well except the lift cylinder which is very erradic when I operate the lever to lift it. I try to feather it slowly, but if the bucket is empty, it is very very difficult to accomplish a smooth lift. What should I look for? It was like this when I got the tractor. The Vickers vane pump was worn out when I got it so I replaced it along with many new lines, but as I said, the movement of the lift cylinder was erradic before I did anything. I am a decent mechanic, but not a student of hydraulics; any help to point me in the right direction will be appreciated.
   / Erradic Lift Cylinder Movement #2
Did you try swapping the lift cyl hose to another spool to check things out?
The nut on back of the lift cyl piston might be loose.
   / Erradic Lift Cylinder Movement #3
You may want to check for bent hyd rod or binding in cyl barrel (dented)....or frozen/rusted pivot pins.....or just an air pocket in the cyl....
Switching the lift cylinder hose to another spool is a good idea. The more I study it, the more I think that particular spool might have a small problem. Could be the spool spring or oring. I am not much for fixing something that still works. I have heard removing a spool can result in something different than what I would hope to find. I noticed that when I first start the machine, the lift cylinder movement is not bad, but after running it for a while the lift cylinder function becomes jerky while other movements are OK. I have read that worn spools do this because as the hydraulic oil warms it becomes thinner which causes the action through the spool to be different. Wish I could know for sure before taking anything apart.
   / Erradic Lift Cylinder Movement #5
I would take things apart until you verify that a particular spool is bad. Just switch the hoses to verify. Perhaps do a pressure check on that spool, and compare to the others.
   / Erradic Lift Cylinder Movement #6
I noticed that when I first start the machine, the lift cylinder movement is not bad, but after running it for a while the lift cylinder function becomes jerky while other movements are OK. I have read that worn spools do this because as the hydraulic oil warms it becomes thinner .
Don't know where you read that, with your description it may be a pump aeration/cavatation problem, Relief valve..??.. Maybe..??.......not spools..
2012 BMW 328i Coupe (A51694)
2012 BMW 328i...
UNUSED LANDHERO MIG-140 WELDING MACHINE (A51248)
UNUSED LANDHERO...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A51691)
2025 Kivel 48in...
2018 E-Z Beever M12R Towable Brush Chipper (A51691)
2018 E-Z Beever...
2022 BOBCAT T76 PLATINUM R SERIES SKID STEER (A51246)
2022 BOBCAT T76...
2019 John Deere HPX615E Gator 4x4 Utility Cart (A51691)
2019 John Deere...
