Buy it or not?
   / Buy it or not? #1
E Needs
John Deere 50
I found a 1956 Jd 50 it's in good shape But not perfect. Has some sheet metal damage and the hood has been cut. Tires are good and it runs good. We are in ohio and prices seem to be a little higher here for some reason, the guy wants $2000. It as the three point and pto. Is this a good buy or not??
   / Buy it or not? #2
If I needed a tractor, I would buy it? Ken Sweet
   / Buy it or not? #3
It's a good price if everything works on that tractor. Any excessive fluid leaks (all old tractors leak some)? Test drive it. Engine should operate smoothly with no hesitation on acceleration. Check operation in all gears forward and reverse while looking for clutch slippage. Check the 2-stage clutch operation to be sure the pto clutch is shifting in and out OK. Verify that the 3pt hitch is operating OK and is staying in the raised position (it's preferable to check this with an implement of some kind on the hitch). Check the gauges for proper operation. If the tractor seems to have a problem with any of these checks, then you have an opportunity to deal off the asking price.
   / Buy it or not? #4
If it has a factory hitch it is a helluva buy what a find!! Good luck in getting in bought
   / Buy it or not?
Well, I called the owner tonight and made the deal. Guess I just bought my first two cylinder Jd!
   / Buy it or not?
Pics of JD 50.
   / Buy it or not? #7
Looks like a great deal from the pictures. Congrats on the purchase. A very good JD to get started with...
Here is our 1954 50. I has power steering (which leaks like a sieve, got to fix someday) and live PTO. We mainly use it on the shredder since it has live PTO.
   / Buy it or not? #8
If it is worth more than $2000 to YOU - then Yes.
If you are "into" antiques in some way - then maybe, but you wouldn't be asking us (-:
Do you have plans for it ?
Would you use it, restore it, sell it on, etc. ?
Your money, your time, your choice (-:
Tennant 800 Ride-On Street Sweeper (A53421)
Tennant 800...
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
2008 VE 500 BBL FRAC TANK (A53843)
2008 VE 500 BBL...
2002 FREIGHTLINER FL70 DUMP TRUCK (A51406)
2002 FREIGHTLINER...
