Rear back blade / Landscaping rake?
   / Rear back blade / Landscaping rake? #1
melvinhatcher
Maryland
1948 John Deere M and 2016 Kubota L3301
I have a King Kutter landscaping rake and Countyline back blade. Is there a way to lubricate the swivel on these implements? :confused:
   / Rear back blade / Landscaping rake? #2
unless you want to go through trying to put a grease fitting on, just oil it as best you can. They will wear no mater what you do.
   / Rear back blade / Landscaping rake? #3
Greasing isn't really necessary. The swivel aren't under any constant load or are swiveled that often.
You can use a spray white grease and give the swivels a good shot. I've done this with a very old (no idea of the brand, but wouldn't be surprised if it's older then I am) rear blade I've had for years...still swivels.
If these implements are left outside, it probably wouldn't hurt to spray them occasionally (prevent rust).
   / Rear back blade / Landscaping rake? #4
If you are really serious drop the blade and apply grease by hand.:)
   / Rear back blade / Landscaping rake? #7
Second the white lithium spray grease and I use a spray silicon grease to spray the whole thing with if I know it's not going to be used for some time and left outside.
   / Rear back blade / Landscaping rake? #8
If you have access to some Cylesso use that. It's kinda stick and spreads over everything quite well.:laughing:
   / Rear back blade / Landscaping rake? #9
That's actually a water displacement spray. Good stuff, but doesn't provide lasting lubrication.
Well, it is a "light lubricant", but I guess the spray grease would be best. I've never used any before...
   / Rear back blade / Landscaping rake? #10
I thought about doing that, but the only thing that concerns me about lubricating the swivels, since they are not sealed, if you grease or oil it, it will attract dirt.
2025 Swict 78in Bucket Skid Steer Attachment (A53421)
2025 Swict 78in...
2019 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
(2) SQUIRREL CAGE FANS (A54757)
(2) SQUIRREL CAGE...
UNUSED 10PCS Industrial Polyester Lifting Straps (A53117)
UNUSED 10PCS...
(4) ELECTRIC MOTORS (A54757)
(4) ELECTRIC...
Chery 7' 35 Drawer Workbench (A50120)
Chery 7' 35 Drawer...
