Rear back blade / Landscaping rake?
   / Rear back blade / Landscaping rake? #1
melvinhatcher
Maryland
1948 John Deere M and 2016 Kubota L3301
I have a King Kutter landscaping rake and Countyline back blade. Is there a way to lubricate the swivel on these implements? :confused:
   / Rear back blade / Landscaping rake? #2
unless you want to go through trying to put a grease fitting on, just oil it as best you can. They will wear no mater what you do.
   / Rear back blade / Landscaping rake? #3
Greasing isn't really necessary. The swivel aren't under any constant load or are swiveled that often.
You can use a spray white grease and give the swivels a good shot. I've done this with a very old (no idea of the brand, but wouldn't be surprised if it's older then I am) rear blade I've had for years...still swivels.
If these implements are left outside, it probably wouldn't hurt to spray them occasionally (prevent rust).
   / Rear back blade / Landscaping rake? #4
If you are really serious drop the blade and apply grease by hand.:)
   / Rear back blade / Landscaping rake? #7
Second the white lithium spray grease and I use a spray silicon grease to spray the whole thing with if I know it's not going to be used for some time and left outside.
   / Rear back blade / Landscaping rake? #8
If you have access to some Cylesso use that. It's kinda stick and spreads over everything quite well.:laughing:
   / Rear back blade / Landscaping rake? #9
That's actually a water displacement spray. Good stuff, but doesn't provide lasting lubrication.
Well, it is a "light lubricant", but I guess the spray grease would be best. I've never used any before...
   / Rear back blade / Landscaping rake? #10
I thought about doing that, but the only thing that concerns me about lubricating the swivels, since they are not sealed, if you grease or oil it, it will attract dirt.
2023 FORD F150 PRO LIGHTNING CREW CAB TRUCK (A51406)
2023 FORD F150 PRO...
30pc 3ft. x 8ft. Red Polycarbonate panels (A55758)
30pc 3ft. x 8ft...
JOHN DEERE ROW MARKERS - SET OF STACK FOLD 12 ROW 30 INCH ROW MARKERS (A55301)
JOHN DEERE ROW...
2017 Ford F-150 Pickup Truck (A55788)
2017 Ford F-150...
199049 (A51243)
199049 (A51243)
2239 (A51244)
2239 (A51244)
