Where do you draw the line between a garden tractor and a CUT?
   / Where do you draw the line between a garden tractor and a CUT? #1
JDgreen227
Super Member
Central Michigan
4210 MFWD Ehydro--'89 JD 318
Over on LMF, I have started a discussion as to what is the dividing line between the two...my argument is whether the machine has the ability to operate a backhoe attachment...if it will run a MMM and FEL and a 3 point attachment, it's a garden tractor.
But to me, when it will run a backhoe in addition to the other attachments, that qualifies it as a CUT. A new member on LMF has a Massey GC 2400, I researched his model and learned Massey sells the same basic model as a GC 2410 with backhoe capability. So, where do you guys draw the line? Thanks.
   / Where do you draw the line between a garden tractor and a CUT? #2
4wd and a loader that carries at least 500# qualifies it to be a SCUT in my book.
Aaron Z
   / Where do you draw the line between a garden tractor and a CUT? #3
Some times the line is blurry.
Look at the original SCUT's. A Farmall Cub could pull a plow, disc, belly mower, seeder, cultivator, sickle mower ect. Some could run a loader, but it was not optimum. Farmall Cub, Allis G, JD LA...
It really is a blurry line some times, and squiggles here and there to boot...
On LMF Muhammad said if the tractor has a ROPS it was considered a CUT, not a GT...he makes an excellent point there.
   / Where do you draw the line between a garden tractor and a CUT? #5
I think traditionally, a lawn tractor did everything but ground engaging equipment.
If it engages the ground with an implement like a tiller, or earth plow, it becomes a garden tractor.
A CUT, or Compact Utility Tractor, to me, at least, is anything from a garden tractor up to the size of a small AG tractor.
I think the term SCUT is just a marketing gimmick so guys can think they are owning something bigger than they really do. :laughing:
Then you have something like my Power Trac. It is not what most folks would call a tractor. Yet it mows the lawn, cuts brush, has several buckets for the FEL, pallet forks, power angle snow plow, etc... over 40 attachments and can run circles around a conventional tractor of the same size on many chores. It cannot pull a dirt plow or pull stumps, however. So what is it? A tool that works really well, that's all. :thumbsup:
   / Where do you draw the line between a garden tractor and a CUT? #6
Gosh, I don't give it any thought on way or the other. I grew up farming with tractors with less HP than some SCUTS have now. I don't really worry about what anyone calls any of my machines and I really don't think there is a good definition that I have thought about it a couple of minutes.
   / Where do you draw the line between a garden tractor and a CUT? #7
It can't be very important. :D
I'd go with Muhammed's classification.
   / Where do you draw the line between a garden tractor and a CUT? #8
Hey, I'm the new member, don't tell my wife it's a tractor, I just told her I was buying a new lawnmower.:laughing::laughing:
   / Where do you draw the line between a garden tractor and a CUT? #9
For me, it has to have both a PTO and a Class 1 3PH.
I'm sure you ask 30 people and you'll get 28 different answers.
Right, it's just a lawnmower...will not say a word otherwise.
PAIR OF 7' HOOK ON TRAILER RAMPS (A51247)
PAIR OF 7' HOOK ON...
2015 JEEP PATRIOT (A51406)
2015 JEEP PATRIOT...
2016 JLG ECOLIFT 70 SELF PROPELLED MANLIFT (A51246)
2016 JLG ECOLIFT...
UNUSED WOLVERINE TQH-26-02C CLASS II 3 PT HITCH (A51248)
UNUSED WOLVERINE...
(APPROX 15) 2" X 6" X 68" THICK TUBING (A51247)
(APPROX 15) 2" X...
2013 3400QB SUNDANCE 5TH WHEEL CAMPER (A52472)
2013 3400QB...
