Comparison Kubota and JD equivalent to Kioti DK55 or NH boomer 4055-60 ?
   / Kubota and JD equivalent to Kioti DK55 or NH boomer 4055-60 ? #1
NorthernChilli
Quebec, Canada
NH TD80D, Ford 1320
Hi all,
What would be the Kubota and JD equivalent to the Kioti DK55, the NH boomer 4055-60 or the Massey 1652-60.
Roughly, 5000+ pounds 55-60 engine hp, 12/12 shuttle tranny, cab. Telescopic and quick connect 3ph ends
Thanks, Phil
   / Kubota and JD equivalent to Kioti DK55 or NH boomer 4055-60 ? #2
Hi all,
Thanks, Phil
you can get a kub MX5100 HST 4x4 w/LA844 fel thats 52hp with 44 pto hp.i bought this tractor in oct 2010 for $24,000.
The 5100 doesn't seem to have a cab option. Does it ?
Phil
   / Kubota and JD equivalent to Kioti DK55 or NH boomer 4055-60 ? #4
Phil
The MX5100 really isn't close to what you have specified - No cab, only 3600 pounds with an 8/8 transmission. The price may be right, though!
In Deere the only model that would fit all of your specs would be the 5065M. 65 engine hp, available factory cab, 16/16 PowrReverser transmission, almost 8K pounds with the cab and MFWD - List Price with Dual Rear and Mid SCV's would be $49,455.00 - not including freight and set-up.
The 5083E Limited might work - 83 engine hp, standard factory cab, 12/12 PowrReverser, just under 7400 pounds with MFWD. List Price with Dual Rear and Mid SCV's is $43,189.00 - not including freight and set-up.
You could look at the 4720 as well: 66 engine hp, available factory cab, but eHydro only and around 4400 pounds with the cab. List Price $42,123.00 with Dual Mid SCV's - not including frieght and set-up.
There are a ton of differences between these three models, and remember - all the pricing is at LIST - before any discounts.
   / Kubota and JD equivalent to Kioti DK55 or NH boomer 4055-60 ? #5
The previous poster already mentioned the deere models so I wont mention them.
But I'd look at the kubota M5140 and M6040. Those two are basically the same tractor. The M6040 weighs a tad more and has 16.9 rear tires instead of the 14.9's.
They fit all of your requirements except the 12/12 tranny. The kubotas have 8f/8r.
But the kubota is 5000lbs+ with the cab and have the telescoping arms.
And when compared to the DK55, it has a stronger 3PH by about 500lbs, loader is a bit stronger, and the kubota has the larger 24" front tires that will give a smoother ride and rut less when doing FEL work. The FEL also has two psitions, a power and a height position. In the height position, it will lift about 20" higher than the kioti, if that is important to you.
If you can live with an 8/8 trans, they are worth a look.
2007 CATERPILLAR D5GXL CRAWLER DOZER (A51406)
2007 CATERPILLAR...
Ford F550 Dump Truck (A47384)
Ford F550 Dump...
2012 Honda Accord Sedan (A51694)
2012 Honda Accord...
2014 Ford F-150 Pickup Truck (A51692)
2014 Ford F-150...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2015 INTERNATIONAL MA025 (A52472)
2015 INTERNATIONAL...
