Best leveling implement
   / Best leveling implement #1
deereman10
Elroy, WI
John Deere 2440
After a field has been plowed, what implement does the best job of leveling the ground and preparing the best seedbed. Disc? Springtooth? etc
   / Best leveling implement #2
Field cultivator with the rolling baskets
   / Best leveling implement #3
Disc with a heavy drag following behind. Ken Sweet
   / Best leveling implement #4
I used a disc harrow for this purpose, and once it is broken up with all the large dirt clods gone there are lots of finishing tools that can be useful. I have found that my landplane with straight blades does an excellent job of smoothing out fields and lawn areas. I assume that what you are asking is really "smoothing" not leveling. Leveling can be a whole new can of worms.
   / Best leveling implement #6
I have found that a cultipacker does really well for preparing a seed bed once the area has been disked. I haven't used one personally, but I have seen fields that have been prepared with a "do-all" and it looked GREAT.
I was also thinking about a cultipacker. Do you think you could skip this discing and just use a cultipacker?
   / Best leveling implement #8
Are you starting at primary tillage with a moldboard plow or chisel plow?
From there disk first.
Then you can run a field cultivator for a fluffy bed or a cultipacker for a firm bed. Skipping the disking will not work with either.
   / Best leveling implement #9
No. Plowing turns over soil/turf without much breakup. Disking then chops it well -- a necessary step.
larry
   / Best leveling implement #10
This looks interesting. It's made by grademaster.
(INOP) 2007 HONDA 420 ATV (A57192)
(INOP) 2007 HONDA...
2010 MAXEY WELDING 20 T/A GOOSENECK TRAILER (A55745)
2010 MAXEY WELDING...
2017 Nissan Titan (A55788)
2017 Nissan Titan...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55853)
2006 iDrive...
ANTIQUE GAS FIREPLACE HEATER (A57192)
ANTIQUE GAS...
2018 XCMG CV83PD (A53317)
2018 XCMG CV83PD...
