Buying Advice gas tank for Troy-Bilt Horse
   / gas tank for Troy-Bilt Horse #1
Twilightwoods
Massachusetts
Troy Bilt 7hp Horse
Hello
I'm lookin for a replacement gas tank, Kohler 7HP spec# 281295, model K161T. Can anyone help a lady out and tell me where to find one?
Thanks a bunch
   / gas tank for Troy-Bilt Horse #2
You should be able to "Google" your model to locate the part #'s. Also you can contact most small engine repair places near you and they can order it for you.
MTD bought Troy Built out, so depending on the year make, you may be able to try them for a replacement.
Good luck
   / gas tank for Troy-Bilt Horse #3
I am assuming it is a plastic tank. If you find a used one be sure it has the fuel cap with it and is the correct one. There are two different type of thread on the tanks. My dealer stuck me for a $20 cap ouch, but was better than the rag that the seller was using.
If the cap threads are just tight blame the ethanol the older plastic caps are doing that even on chainsaws.
   / gas tank for Troy-Bilt Horse #5
   / gas tank for Troy-Bilt Horse #6
$105 guess thats why my cap cost 20 bucks, what a racket on parts. It is almost cheaper to buy a harbor freight engine for $89 and switch.
2007 Hino 268 Truck, VIN # 5PVNE8JVX72S50442 (A51572)
2007 Hino 268...
2012 WABASH 53FT DRY VAN TRAILER (A52576)
2012 WABASH 53FT...
2015 FREIGHTLINER SPRINTER VAN (A52576)
2015 FREIGHTLINER...
2001 TRIPLE E INDUSTRIES 48X102 TRI-AXLE STEP DECK (A52472)
2001 TRIPLE E...
2017 FORD F-250 SUPER DUTY (A52472)
2017 FORD F-250...
2014 Utility Trailer 4000DX 53ft. T/A Dry Van Trailer (A51692)
2014 Utility...
