LD1
Epic Contributor
Stick with the 5 footer.
A larger bushhog doesnt necessarialy mean it will cut faster. It takes more HP to run and usually means a slower ground speed. Especially in thicker stuff.
It has been said several times that it is PTO HP that determines how fast you can cut, NOT cutter size. A smaller one will take a smaller bite, but can sustain a faster ground speed.
Its kinda like comparing my 14 HP JD 240 garden tractor to a 20+ HP zero turn. The ZTR can mow at a faster ground speed cause it has the HP to back it up.
And I am not sure how hilly or flat your 5 acres is, but a 6' cutter on a light tractor like that isnt fun on hills. Leaving the FEL on is almost a must. But then you give up manuverability. Not to mention, there IS a pretty good price jump.
