New to friction clutch
   / New to friction clutch #1
Knight
CT
Kubota L3400
While restorting as harley rake I decided to add a slip clutch because of the damage encounter by rollers jamming, chain jumping sprokets and pillow block bearings breaking.
As I was removing the old coupling from the gear box, it had a friction clutch. I never seen one before. It had springs and little angled cylinders, which would slip under load. Maybe this clutch was frozen. Do friction clutches need grease? I like the slip type because I it has adjustment to it.
Are friction clutches a thing of the past. Does anyone have experience with them?
   / New to friction clutch #2
No grease, otherwise they are useless as a
method for the for the implement to prevent damage.
So it seems you have A Weasler brand torque limiter of some type
(ratcheting apparently) of which there are 4 current model types.
2016 CATERPILLAR 325FL CR EXCAVATOR (A52705)
2016 CATERPILLAR...
2004 INTERNATIONAL DURASTAR 4300 BOX TRUCK (A55745)
2004 INTERNATIONAL...
1000 Gallon 6 Lug Water Wagon (A50775)
1000 Gallon 6 Lug...
2015 Volvo VNL 64T (A55302)
2015 Volvo VNL 64T...
2017 Ford F-450 Reading Service Truck (A55788)
2017 Ford F-450...
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A55788)
2009 Peterbilt 384...
