LGB Angled Grader !
   / LGB Angled Grader ! #2
All of these things work well from what I have seen, I prefer something a little more sturdy as I use mine commercially. On mine the blades are mounted on 5/8" x8" x 96" flatbar set at 45 degrees with 3x3x 3/8 angle boxing it in on each side. Most lighter models use a single piece of 4x4x3/8 or 4x4x1/2 angle to mount the grader blades. Probably more efficient and less cost and seems to work well too. Its all good though.
I am building a pad for my new shop the last day or so and the landplane/grader proved to be great for smoothing out the fill between the layers and compacting. Using my 110 fel to place the dirt, the 4520 to smooth and level and a Case vibratory roller to compact everything. Moving a total of about 360 yards of engineered fill for this project.
   / LGB Angled Grader ! #3
Steve, how big is your shop going to be? It is so cool :cool2: that biz is good enough that you are able to do this. :thumbsup: :thumbsup:
Only problem so far is , that it cuts SO deep , that it pulls up the red rock under the white rock , if they have a thin layer of white rock . Still loving it m did 3 more driveways today !! :D
   / LGB Angled Grader ! #5
Brian,
Just a small shop 30x40x10 plus side covered parking 25x40.
Should I run my lift arms in lock postion , or let them float ? I have them on lock now .
   / LGB Angled Grader ! #7
Alot would depend on how you use it. I use topntilt for mine so the locked positions enable me to tilt to a given angle and hold that position. Never used one without the tilt but suggest you try it both ways and let us know what you find.
I think it did better on float mode , it did not dig in to deep . Still have 8 driveways to do :confused2:
   / LGB Angled Grader ! #10
Mine took some playing with it to figure out the best way for it to grade in each scenerio. Just keep trying small changes and you will figure it out as to what works best. First time I used mine I thought it was digging for China!
Jenkinsph, if mine were any heavier my 70hp ag tractor wouldn't lift it. If you want heavier get out your welding shield. David from jax
2016 KBH Fertilizer Tender Trailer - Isuzu Diesel, Hydraulic System, Rear Discharge (A53472)
2016 KBH...
Miles read : 112,969 (A50323)
Miles read ...
2008 INTERNATIONAL 4300 M7 SBA 4X2 DUMP TRUCK (A51406)
2008 INTERNATIONAL...
2009 MACK GRANITE (A52472)
2009 MACK GRANITE...
New/Unused Mower King 48in Quick Attach Trencher (A51573)
New/Unused Mower...
(1) MAGIC CHEF REFRIGERATOR (1) LG REFRIGERATOR (A51248)
(1) MAGIC CHEF...
