Welded Cylinder, dissasemble, and weld crosstube onto?
   / Welded Cylinder, dissasemble, and weld crosstube onto? #1
cruzer
Member
I have two cylinders at work that are no longer needed - would like to use them for a loader, but they do not have mounts on the end of the body, only the side like they were mounted flat to a plate. Can i remove the guts (piston rods etc) and weld on a cross tube to the bottom of the cylinder?
thanks
   / Welded Cylinder, dissasemble, and weld crosstube onto? #2
Yes you can. Or, you could probably get by just extending the rod out to get the piston seals away from the heat and weld it that way. Wrapping wet rags around the tube will help draw the heat away too.
Kim
Great! Thanks for the response! I thought that was the case but wanted to make sure.
Cruzer
   / Welded Cylinder, dissasemble, and weld crosstube onto? #4
Kim
What Kim said...
But also you need to be carful you don't get it to hot and warp/distort the cylinder tube.
   / Welded Cylinder, dissasemble, and weld crosstube onto? #5
You might try this little trick. Remove the piston assembly. Plug the base end port, and fill the tube with water. Then sit the base end, vertical on the cross tube or whatever, and weld . The water will absorb the heat.
2017 Taylor-Dunn B0-248-36 Electric Utility Cart (A50324)
2017 Taylor-Dunn...
UNUSED RAYTREE RMDM70 - 70" HYD DISC MULCHER (A52706)
UNUSED RAYTREE...
VERMEER RTX 130 WALK BEHIND TRENCHER (A51242)
VERMEER RTX 130...
2021 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54313)
2021 FREIGHTLINER...
2015 Freightliner 122SD Day Cab Truck, VIN # 3AKJGND64FDGH1772 (A54865)
2015 Freightliner...
2016 Mitsubishi Fuso FEC52S Cab and Chassis Truck (A55852)
2016 Mitsubishi...
