is 2500 hours a lot...
   / is 2500 hours a lot... #11
Thanks crazyal. I'm going to look at it today if all goes well and I'll add what you suggested to my growing checklist. If I think it's o.k. is it unreasonable to give the owner a small deposit and have it checked out by my diesel mechanic friend when I go to pick it up? Can I expect a deposit back if he says it has some major issues that I missed?
Thanks again,
Rob
Nothing is unreasonable if the seller agrees to it. It would be better (IMHO) if you can take your friend on the first visit.
True, Roy, true. I should be able to tell what type of person I'm dealing with by his response.
I would bring him but he's also the one with the trailer and truck that will haul it home and the tractor is an hour and a half away so it's a lot to ask to make the trip twice.
   / is 2500 hours a lot... #13
On a small tractor that seems like a lot to me. If you want to take your chances you can get tractors a lot cheaper.
Chris
   / is 2500 hours a lot... #14
There are 8760 hours in a year.
If you ran a tractor 8 hours per day, every day for a year, that would put 2920 hours on the clock.
If you ran a tractor 8 hours per day every weekday for a year, with time off for weekends, federal holidays, and 30 days vacation away, that would put 1768 hours on the clock.
A landscaper company may run that tractor 4 hours a day average, with a lot of idle time (unless they're really tight on fuel costs), so that's 884 hours a year of pretty heavy use.
Farm tractor use is really variable. You might be running it 16 hours during haying, harvesting, or planting season. And it might get a 30 minutes to an hour total during the day in the winter. Depends on the tractor and the farm. Hobby farms will probably see even less.
Weekend warriors are likely to put maybe an hour on the clock during the week, and maybe 4 to 8 max during the weekend. But they don't do that every weekend. Which means it takes a long time to add hours.
I look at a used tractor with 2500 hours on it, i figure it's either it's old, or it's been used hard. Expect problems with it. Know ballpark of how much repairs will cost. Go over it with a fine toothed comb, and add those probable costs to the sale price. It might not look like such a bargain afterwards.
Thanks, Doc. The seller has other bigger tractors for sale with a lot of hours on them as well. I'm not sure of the year yet but the range of production was '87-'99 so if it were an '87 that would be approx 104 hrs/yr and if it is a '99(which I'm pretty sure it's not based on the pics) that would be approx 208 hrs/yr.
The problem is that OLD is my price range....
   / is 2500 hours a lot... #16
Then I suggest you be fair to the seller.
When you go and it turns out you like the machine and put a downpayment on it, do your best to return within a day or so. The seller may miss other potential buyers by holding it for you.
If I was the seller, I probably wouldn't take a deposit (which would leave me free to sell it).
Good luck to you on this tractor.
Good points, maybe I'll have a look and go back with the trailer if it's still available within the next day or two without leaving a deposit. Thanks for all the help.
Nice hat by the way!
   / is 2500 hours a lot... #18
As with others, I wouldn't worry about the hours, just have someone knowledgeable check it out, that's what I do.
   / is 2500 hours a lot... #19
Hi, 2500 hours is nothing! Our ford has got 15,000 on it and only just done a rebuild, also keep in mind machine hours are not the same as human hours, diesels count there hours based on a set engine rpm, most are around the 1800rpm mark but the do differ. What this means is you can only take the hours as a ruff guide. The example being if the previous owner has done lots of work with it but only at low rpm ( most hobby users) then the engine is rarely under it's rated load, then this can lead to worn bearings and carbon buildup just to name a couple of options. This engine would show low hours but might have problems. On the other hand, an engine that is run flat strap all the time but not under load is going to gain hours quickly, so that kind of operation is going to have done damage aswell. My point with this is don't base your decision on hours as it's only a very small part of the story.
I would be more concerned about how the tractor looks, how easily does the engine start? When it first starts what comes out the exhaust? when it's running and you rev the engine does it respond quickly (good) or slowly(fuel timing problems) does it bellow Hugh amounts of smoke? Take it for a test drive, try it in all the ranges and gears, do all the gears feel the same, even across the ranges, some times driving a tractor in high range all the time can mask gear problems when you put it in low range and vise versa. How Does the clutch feel? Are the brakes good? With the tractor in a low gear and decent rev's stamp on the brakes, does the engine die or can it hold on, or do the brakes not do anything? This simulates the tractor under load. and will give you good insight into the engine's ability to pull. Feel the steering and watch the wheels is there any slop? If there is this could mean hydraulic problems ( presuming power steering) once the tractor has been running for a while check the temp gauge, it should read around 80 deg C, have a feel of the bottom of the radiator, carefully it will be hot, but should be around 50deg C have a good look at all the greasepoints do they look like fresh grease covering up old caked up grease? Or does it look well maintained? With loaders and back hoes, look for wear on pins and joints, with the implement off the ground move it side to side by hand ( machine off) and see how much movement you get? If bush's are good you should get almost none.
Check for oil leaks around the transmission, these can be costly to fix, and the old rule is if oil can get out, dirt can get in.
Follow these steps and you should have a really good idea of what your up for.
Thanks for all the tips and your perpective Andrew! Nice to hear from a Ford user with a ton of hours on their machine. I'm going to at least have a look this afternoon armed with an inspection list.
2008 OVERLAND TANK KILL TRAILER (A52472)
2008 OVERLAND TANK...
2012 PROCO 130BBL VACUUM TRAILER (A53843)
2012 PROCO 130BBL...
SET OF (4) ALCOA 24.5 ALUMINUM RIMS (A53843)
SET OF (4) ALCOA...
2014 GENIE GS-2632 ELECTRIC SCISSOR LIFT (A53843)
2014 GENIE GS-2632...
2015 TEXAS PRIDE  GOOSENECK (A53843)
2015 TEXAS PRIDE...
2015 Eager Beaver 15HBB-PT T/A Flatbed Equipment Trailer (A50322)
2015 Eager Beaver...
