Sheepsfoot roller for CUT? Pic
   / Sheepsfoot roller for CUT? Pic #1
Slacker
Gold Member
Durham, NC
Farmtrac 360 TLB
I've got two sets of remotes, flow is around 8.5GPM. Has anyone ever seen a vibrating roller attachment for a CUT? Building a dam in 12" lifts, it sure would be handy to rent one.
   / Sheepsfoot roller for CUT? Pic #2
The Bobcat vibratory roller requires 20 gpm for the smaller units. You don't have the optimum flow. The smaller rollers also weigh 1800 lbs. Can your CUT handle the weight? I would just load down your CUT with dirt in the bucket and heavy rear attachment and just pack it as you build the dam.
   / Sheepsfoot roller for CUT? Pic #3
   / Sheepsfoot roller for CUT? Pic #4
12" lifts? That's too thick.
6" lifts would be much better.
You can pack it with heavily loaded tractor tires. Fill your loader bucket and tote a round bale on the back and just drive back and forth.
   / Sheepsfoot roller for CUT? Pic #5
Another possible concern with using a CUT is does it have an oil cooler? If not the oil may get hot while running a roller.
(APPROX 32) 6' X 12' HEAVY CHAIN LINK SITE PANELS (A54757)
(APPROX 32) 6' X...
72" Grapple (A53316)
Utility Tilt Trailer (A55788)
Utility Tilt...
New JMR Skidloader Stump Bucket (A50775)
New JMR Skidloader...
2010 Turfco Mete-R-Matic III Pull-Behind Top Dresser (A54811)
2010 Turfco...
2018 John Deere 470G Hydraulic Excavator (A55787)
2018 John Deere...
