gas welding carbon steel to stainless
   / gas welding carbon steel to stainless #1
handirifle
Central Coast of CA
Massey Ferguson 1010
Is there anything other than brazing that can be done to join these two dissimilar metals? It's a gas only proposition.
   / gas welding carbon steel to stainless #3
They're compatible. Just go ahead and weld it with steel filler rod.
   / gas welding carbon steel to stainless #6
I found a little, (very little) bit about welding stainless steel with O/A in one of my old books.
Tig, and SMAW are probably the two cheapest processes to get going. Mig would mean a tri-mix gas which most people don't have on hand.
   / gas welding carbon steel to stainless #7
When I worked at a cannery, all the shoots were SS. We put legs and braces on them that were mild steel. We just used a SS rod on a DC stick welder. No big deal.
Why is that?
Due to space. It's a small part and I silver brazed it before, but it didn't hold. So I am wondering if welding with the steel filler rod idea will, indeed, work?
I don't have a tri-mix gas for the mig, and would be afraid to try it. Would sil-fos work? I have tons of experience with sil-fos, but never with these two metals. I have a lot of silver solder time as well, but this did not take well to it, for some reason. Maybe it got dirty by my earlier attempts, not sure.
   / gas welding carbon steel to stainless #9
In "Normal" welding techniques, its proper to use stainless filler to make the connection between steel and stainless...not steel filler.
OK thanks, I was told by others, before, to use the silver solder.
New/Unused 7ft Workbench (A51573)
New/Unused 7ft...
NEW Wolverine Fixed Mini Excavator Thumb Attachment (A53002)
NEW Wolverine...
PENDING SELLER CONFIRMATIONS (A52576)
PENDING SELLER...
Skid steer auger plate (A50322)
Skid steer auger...
1265 (A50490)
1265 (A50490)
2015 PETERBILT 365 (A52472)
2015 PETERBILT 365...
