JD 4310, Front Axle Leak?
   / JD 4310, Front Axle Leak?
Hope this helps, my reply in bold letters.
JB,
Part # 22 is listed as a "seal" on that drawing - it has a JD number of LVA16814. The only other part shown there is #33 - which is'nt where I would think your leak is. I attached a link below directly to the JD parts page - just enter 4310 in the model block (left upper portion of page) then scroll down and pick the 4310 tractor.
John Deere - Parts Catalog
Thanks guys, Have not looked into it any further, yesterday there was not much leaking? Have not checked today. Machine has around 600 hours.
I don't get to excited about a little wet around a seal/gasket, but this got my attention when it left a spot on the floor. I'm sure I'll have to address the mater sooner than later.
JB.
   / JD 4310, Front Axle Leak? #12
Least you can do is check the dip stick to keep oil in the axle housing.
Has it dropped? Or is it empty, and that is why it has stopped leaking so much? :D
   / JD 4310, Front Axle Leak? #13
Just finished one side on this job, taking a lunch break. The job is not too bad, but If one is not a moderate/advanced DIYer, I would not recommend it. I ended up *not* having the tapered bearings (which is a more difficult job). A hydraulic press is required to do the job properly -- would not touch it without it.. Harbor Freight had their middle one on sale today and, with the 20% coupon, came out to be a little bit more than $100. The thing that makes the job more difficult is that the instruction sheet that comes with the seal specifies a .060" rise above the housing. I have depth gauges, so I was able to measure it precisely. I assumed that JD must be having problems with these seals because 1) they have been updated and 2) they have a precise depth for the seal. Now, of course, the reason for the precise depth is that the new seal also has a "flange" that "rides" on the hub facing the tire (in addition to the "typical" sealing surface) -- hence the precise depth measurement. During assembly, when I put the outer bearing in and seated it, the hub had a little more resistance than I was comfortable with when turning to check it, but I assumed that this was because of the additional mating surface for sealing. However, by the time that I had installed the inner bearing, the turning tension was less.
For those that are uncomfortable doing this job, the removal of the hub from the axle is *easy* and, if done by an owner that is not putting the seal in, this would enable you to take the hubs to any repair/machine shop and have the seals installed without taking the tractor.
More later if I have any additional observations . . .
Richard Easley
Waco, Texas
I thought about that myself, But really we are talking about maybe a couple of ounces so far. Every time I've ever checked it, it's been right on, but since it's been a few months I will look today.
Richard Easley
Waco, Texas
Richard, do you have the exact same model as me, 4310?
I thought I could handle a seal replacement job no problem, plus the guy that works for me is a pretty good mechanic. I have every tool possible except the press, and I have at least a few friends that have presses.
But I admit alot of what you are describing makes me a little uncomfortable, I thought it would be a straight forward part replacement, but sounds like there are some variables.
I know I can handle the hub removal and maybe when I see it all apart I'll figure it out, but if I have to bring it to the shop to be done right, it wont hurt my pride any. I would probably bring it to the JD dealer as they may be familiar with any quirks with the specs.
Thanks for the experience.
JB
   / JD 4310, Front Axle Leak? #15
But I admit a lot of what you are describing makes me a little uncomfortable, I thought it would be a straight forward part replacement, but sounds like there are some variables.
JB
Good evening, JB --
I have a 4300 but I reviewed a few previous posts on the site and I would bet that your hub is the same as mine.
A little more discussion on the seal: it is not the "traditional" one-piece seal, where the sealing surface "rides" in the surface of the hub, instead, it is a two-piece seal and the second part of the seal is attached fro minside the housing after the outer seal ring is installed on the housing. Also, the second part does *not* rotate on the surface of the hub; instead, it is "fixed" to the surface of the hub (read: a resistance fit, not bonded) then, as the hub rotates, this inner seal rotates against the "outer" seal (the one pressed into the housing.
I have done a lot of automotive work through the years and had never encountered one of these before. After doing a little web research, apparently they are quite common in heavy-duty applications and quite common in the trucking industry.
After doing the job, I agree that, if you don't do it yourself, I would take it to the JD dealership and let them install it.
If you do end up doing it yourself, the seal installer from John Deere is just $30. The part number is JDG11067.
Note that I have posted the procedure on a new thread called " Replacing Front Seals in John Deere MFWD Tractors With Two-Piece Seals," so that it can be found easily if needed . . .
Richard Easley
Waco, Texas
Good evening, JB --
Richard Easley
Waco, Texas
OK thanks again,
I'll check out your other thread.
The thing stopped leaking, not even a drop now :confused2: checked the level and it was right up where it should be and looked clean as honey.
JB.
UNUSED WOLVERINE BC-13-72W 72" HYD BRUSH CUTTER (A54757)
UNUSED WOLVERINE...
2019 New Holland Workmaster 95 MFWD Compact Utility Tractor with 632TL Loader - Poultry Special (A55302)
2019 New Holland...
1981 AZTEC SKINNY NECK 31 FOOT FLATBED (A53843)
1981 AZTEC SKINNY...
Kubota K7874 18in. Bucket (A52377)
Kubota K7874 18in...
2011 IC Corporation PB105 School Bus (A52377)
2011 IC...
JOHN DEERE 635F 35' HYDROFLEX PLATFORM HEADER (A51247)
JOHN DEERE 635F...
